B18 in a 4th Gen?
Old Feb 2, 2006 | 09:21 PM
IcebergMan's Avatar
Default B18 in a 4th Gen?
Hi,
I'm thinking about getting a 4th Generation Accord for a daily driver and was thinking about swapping a B18C1 into it. Would this be possible? I know that the H22 is the most common Accord swap but I was curious if this would be possible. Would a lot of custom work have to be done? Or no more than the H22?
If that's not going to work out then I think I'll go with the H22. I know that the H22 is a very common swap in the Accords but all of the ones that I've seen are for newer generations, would it be just as easy in a 4th Generation? I'm assuming it would be but I just want to check.
Thanks guys!
Old Feb 2, 2006 | 09:25 PM
momstaxi's Avatar
Default Re: B18 in a 4th Gen? (IcebergMan)
b series motors into 90+ accord questions seems to get everyone riled up around here ...
but no, the simple answer is that it wont work, alot of custom pieces would need to be fabricated, for not really any gain....
just go with an h22 id say, but any h series or f series motor will fit your accord, do a search and youll see many reasons why you shouldnt do b series...
Old Feb 2, 2006 | 09:27 PM
IcebergMan's Avatar
Okay, thanks. Just wanted to make sure that an H22 was possible in a 4th Generation.
Old Feb 3, 2006 | 05:39 PM
SneezinCD5's Avatar
Keep the F22. If you wanted to swap a low milage f series and
boost it!
elbrendo
Jan 23, 2007 12:22 PM
92hondalude
Apr 20, 2006 09:38 PM
Stevorh
Feb 14, 2005 05:40 PM
TurboCustomz
Sep 16, 2004 02:14 PM
