FS: 1993 Del Sol w/ JDM B16 -- 45K Miles -- MINT -- $4300 -- PICS
SOLD SOLD
THE GOOD
Engine/Performance:
CLEAN TITLE/PINK SLIP IN HAND !!!
* B16A 2nd Generation w/ 45K miles. (The healthiest b16 ever)
* Brand new Axles, belts, seals, etc.. ABSOLUTELY NO LEAKING OF ANTYHING.
* 5-speed transmission.
* Clutch Specialties 4 Puck Clutch
* ACT Prolite 8 lb. Flywheel
* Real ITR (Integra Type R) Header off 2001 ITR
* Hollowed Cat
* Skunk2 2.5" Full Catback Piping with OBX Twin Loop Muffler
* Injen Short Ram Intake (Red)
* NGK Wires & Platinum Plugs
* Socketed and Chipped ECU
* Vtec 6000 rpm --> Red 8700 rpm -- No Speed Limiter/Governor Fully tuned
* NO AC/NO PS
* B&M FPR (Fuel Pressure Regulator)
* Crankcase Air Breather
--there is probably more, i just can't think
Interior:
INTERIOR IS PERFECT. Everything Works, No Rips/Tears/Stains !!! You won't be disappointed.
* Del Sol Black Seats with Red Stripe
* Sony CD/Headunit.
* JL 3-ways all the way around
Exterior:
* Targa Top in Excellent Condition (Fits in Trunk)
* OEM Polyurethane Front/Back Bumper with Sideskirts (Need painting -- took off body kit cause it looked like ****)
* OEM Carbon Fiber Hood with pins.
* Lexus IS 300 Color Paint Job - IS Silver is the color.
* Stock rims and tires. (Look like Rota Circuit 8's) -- 70% tread left
* No AUX Lights. (Helps air flow)
* Coilovers
* Shaved emblems and antenna.
* Clear Corners
***** Registered till March of '06
THE BAD
I am a very honest seller therefore, i tell you exactly what is wrong even down to the itty bitty things you would never notice.
1. Windshield has crack (was not cause by rock, i think the change in the weather did it)
2. Front and Back bumper are black. Need color matched. Cost $150
3. That's it. EVERYTHING IS GOOD TO GO !!!
<U>Pictures are below:</U>
Modified by CALIdelsolSIR at 10:05 PM 2/15/2006
THE GOOD
Engine/Performance:
* Hollowed Cat
* NO AC/NO PS
Interior:
* Sony CD/Headunit.
Exterior:
* Coilovers
* Clear Corners
THE BAD
CALIdelsolSIR
Feb 14, 2006 05:34 PM
CALIdelsolSIR
Feb 14, 2006 05:33 PM
CALIdelsolSIR
Feb 14, 2006 08:34 AM
CALIdelsolSIR
Northern California (Sales)
13
Feb 13, 2006 04:54 PM
CALIdelsolSIR
Feb 10, 2006 08:43 AM
