HELP with REM OVING a L BRACKET FROM A 96 GSR
Old Feb 2, 2006 | 08:31 PM
DJNauTicz's Avatar
Default HELP with REM OVING a L BRACKET FROM A 96 GSR
anybody know a DIY or LInk how to remove a L bracket from a 96
LS OR GSR ?? please help..need help to remove it from my friends car and put it into my car...
Old Feb 2, 2006 | 10:28 PM
LSvtec03's Avatar
Default Re: HELP with REM OVING a L BRACKET FROM A 96 GSR (DJNauTicz)
what bracket are you talking about?
Old Feb 2, 2006 | 10:49 PM
biada2.9's Avatar
Default Re: HELP with REM OVING a L BRACKET FROM A 96 GSR (LSvtec03)
its the bracket right next to the flywheel cover.
well, thats where my L-bracket is. it was once in the way of my flywheel cover and i couldnt install the cover on.
anyways, i got someone to adjust it for me and everything is G..
Old Feb 2, 2006 | 10:59 PM
DJNauTicz's Avatar
is L Bracket..the bracket..in the rear of the ENGINE......
that connect btw the firewall to the engine..the one connect in the rear engine...
that's the bracket i'm talking about.........
something like this..is in the rear engine...please help..i wanna know how to take that out..from a engine...please help
Old Feb 2, 2006 | 11:09 PM
LordAphotic's Avatar
you have to take the bolt off thats on the other side of the starter. then theres two bolts that you have to get from under the car. they are 19mm. then once those are off you should be able to take the tranny off if thats all thats left to remove. if you want to take the whole piece out then unbolt the rear motor mount. the whole mount. theres 3 small bolts i think they are 14mm then take off the whole thing side ways.
Old Feb 3, 2006 | 05:53 PM
DJNauTicz's Avatar
Default Re: (LordAphotic)
this is a rear engine mount..is not a tranny mount...it's easy to take it off or it's hard ????
RyanR
Paint and Body
Aug 15, 2012 11:02 AM
Blk00EJ8
Feb 29, 2008 07:03 AM
egtype-r
Mar 5, 2005 05:43 PM
