oem type r bars on non type-r's??
Old Mar 24, 2002 | 11:37 PM
slomob18b's Avatar
Default oem type r bars on non type-r's??
Hi, I was just wondering if the front strut bar, rear strut bar, and lower tie bar from an Integra type r fit into a 98 integra ls? thanks
Old Mar 25, 2002 | 12:39 AM
comptechgsr's Avatar
Default Re: oem type r bars on non type-r's?? (slomob18b)
yes
Old Mar 25, 2002 | 02:42 AM
5-SpeedFreak's Avatar
New User
Default Re: oem type r bars on non type-r's?? (comptechgsr)
yes
Old Mar 25, 2002 | 02:58 AM
slomob18b's Avatar
is the lower tie bar a bolt on thing? i have heard that a bracket is needed to keep it to the subframe. is this true? thanks alot guys
Old Mar 25, 2002 | 05:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ITR rear tie bar screws directly into the subframe. Non-ITR's have nothing in this location so you should be able to install it there. USDM ITR's don't have rear shock tower braces, but you can find JDM ITR ones at several places.
Old Mar 25, 2002 | 05:49 AM
AcuraRacer112's Avatar
Default Re: oem type r bars on non type-r's?? (PatrickGSR94)
well this is some what correct...you need a BSQ mounting kit...unless you like rippin' the frame on you car do to the stiffness of the bar, you cannot directly bolt it to the subframe of your LS that would be bad...
[Modified by AcuraRacer112, 2:49 PM 3/25/2002]
[Modified by AcuraRacer112, 2:50 PM 3/25/2002]
Old Mar 25, 2002 | 05:55 AM
letsride's Avatar
Default Re: oem type r bars on non type-r's?? (AcuraRacer112)
I think he was talking about the tie bar and not the sway bar!!
Old Mar 25, 2002 | 05:59 AM
Default Re: oem type r bars on non type-r's?? (letsride)
ahhh...gotcha...well i guess that is a freebie on the how to install a type r sway bar
Old Mar 25, 2002 | 01:05 PM
slomob18b's Avatar
thanks alot everyone for the answers. it really helped alot
Old Mar 25, 2002 | 02:51 PM
IN VTEC's Avatar
"Aluminum strut tower bar [front]" - Yes. Direct bolt-on.
"Performance Rod added to rear cross member" - No...not unless you're into welding.
"Rear performance rod" - No...not unless you like to drill holes.
JDM Rear Strut Tower Bar
ITR 22mm Rear Swaybar
Old Mar 25, 2002 | 07:58 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: oem type r bars on non type-r's?? (IN VTEC)
I wanted to get the rear performance rod, but the holes don't have any threading on my gsr
Old Mar 26, 2002 | 02:39 AM
slomob18b's Avatar
so the usdm type r lower tie bar does not bolt onto an ls right? thanks
Old Mar 26, 2002 | 08:59 AM
2005 TSX's Avatar
Default IN VTEC
Cool, those are pics of my car!!!
Old Mar 28, 2002 | 09:18 AM
reefer_bob's Avatar
I would disagree with the front upper being a direct bolt on. It is if you have the set of attachement bolts, however on the LS, those holes are just plugged, and there are no studs there. On the GSR, there are studs, and the bar is a direct bolt on. In addition to the bar, you also have to get the bolts, since I would assume that no one is gonna knock their bolts out for you...
Reefer_Bob.
Old Mar 28, 2002 | 06:42 PM
slomob18b's Avatar
MechEng
Dec 24, 2008 10:36 AM
01-0720
Mar 29, 2006 04:33 PM
1995chardx
Nov 9, 2005 04:54 PM
Spartanic
Mar 24, 2004 06:13 AM
integraautox
Sep 14, 2002 06:23 AM
