Avid rod shift linkage for the H-series.
Old Feb 2, 2006 | 03:59 PM
Antilag's Avatar
Default Avid rod shift linkage for the H-series.
Well since NHRA will not let me run the h2b adapter plate, i want to try to eliminate the hseries weakpoint. The shift linkage! This rod **** linkage, i don't know much about. Who has this and how well does this work for you? Do i need to cut into the firewall? Or is this a direct bolt on. Come on someone out there has got to have this. Thanks
Old Feb 2, 2006 | 04:02 PM
ihaterice's Avatar
Default Re: Avid rod shift linkage for the H-series. (9sech22civic)
with the b series tranny wouldn't you run the b series shift linkage?
Old Feb 2, 2006 | 04:07 PM
buck02's Avatar
Default Re: Avid rod shift linkage for the H-series. (ihaterice)
well he wont be using the b-series tranny cause nhra wont allow him to!!!
Old Feb 2, 2006 | 04:11 PM
Antilag's Avatar
Default Re: Avid rod shift linkage for the H-series. (buck02)
I wanted some opinions before i decided to invest in this part.
Old Feb 2, 2006 | 04:48 PM
ihaterice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">well he wont be using the b-series tranny cause nhra wont allow him to!!!</TD></TR></TABLE>
i am a dumbass - just re-read
Old Feb 2, 2006 | 05:11 PM
Antilag's Avatar
Its all good James, atleast you dont **** into flower pots!!
Modified by 9sech22civic at 9:41 PM 2/2/2006
Old Feb 2, 2006 | 05:49 PM
buck02's Avatar
nor take a leak in a flower pot downtown orlando
hahaha
has mark taken rids on the bicycle taxi latley with a hot driver
Old Feb 2, 2006 | 10:12 PM
bracket 4 life's Avatar
bump cause I would like to know also
Old Feb 2, 2006 | 10:36 PM
Ekasey's Avatar
Picking up scavengers after the club let out huh?
Old Feb 3, 2006 | 02:59 AM
tagperformance's Avatar
Who did you talk to in the nhra that said you couldn't run the plate in competition?
Old Feb 3, 2006 | 03:34 AM
Tyler H's Avatar
This freakin' Avid linkage is like Sasquatch. I've never actually seen a picture of it installed!
The H2B setup is not legal in NHRA for sportsman classes (Sport FWD and Street Stock). It is allowed in pro classes (All Motor, Hot Rod, Pro FWD), but there might be a weight penalty. Check the rules specific to your particular class.
Tyler
Old Feb 3, 2006 | 06:32 AM
YZFR6's Avatar
Hey, everyone. I am going to e-mail my good friend James Innes and he will put up the pics for me. I can't upload it. Sorry, you'll see it in the next couple of days. Thanks.
Old Feb 3, 2006 | 08:07 AM
Antilag's Avatar
Default Re: Avid rod shift linkage for the H-series. (YZFR6AVID)
Thats cool and all, But tell us more about it. The Advantages, clearance, Quicker and more accurate shifting???
Old Feb 3, 2006 | 09:02 AM
Dragline's Avatar
You have to run solid mounts with these shift bars..and I would say that the would definitely make for A way more accurate shift then the cables, they would have to with everything solid.
Old Feb 3, 2006 | 10:03 AM
buck02's Avatar
Default Re: Avid rod shift linkage for the H-series. (Dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote"> You have to run solid mounts with these shift bars..and I would say that the would definitely make for A way more accurate shift then the cables, they would have to with everything solid.</TD></TR></TABLE>
well solid mounts would deffinetly help steves advantage for the top mount on movement and the way the wastegate sits solid hasport mounts and radius arms to the block off the traction bar
Old Feb 3, 2006 | 10:15 AM
tony1's Avatar
Has anybody ever looked into upgrading to bigger cables for the shifter? They make them, and i can't see any reason they wouldn't work if the problem is the cables flexing. Look into Morse cables, they have ALOT of different sizes and end options. They can build custom stuff as well.
Old Feb 3, 2006 | 11:21 AM
Antilag's Avatar
Default Re: Avid rod shift linkage for the H-series. (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Has anybody ever looked into upgrading to bigger cables for the shifter? They make them, and i can't see any reason they wouldn't work if the problem is the cables flexing. Look into Morse cables, they have ALOT of different sizes and end options. They can build custom stuff as well. </TD></TR></TABLE>
Tony thats a hell of an idea. I'll look into that.
Old Feb 3, 2006 | 11:25 AM
ihaterice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YZFR6AVID &raquo;</TD></TR><TR><TD CLASS="quote">Hey, everyone. I am going to e-mail my good friend James Innes and he will put up the pics for me. I can't upload it. Sorry, you'll see it in the next couple of days. Thanks.</TD></TR></TABLE>
Geez, now you are calling me your friend - you drink too much of that Canadian Beer today or do you have a Mounty standing behind you telling you to say that ???
Modified by ihaterice at 3:45 PM 2/3/2006
Old Feb 3, 2006 | 12:11 PM
Dragline's Avatar
I don't know if the Morse cables can handle that abuse I always had problems with the crimped ends separating from the cable sleeve after time, I have had better luck with Cablecraft they make alot beefer cables, they have alot more options as far as cable sizes and quality. I think they make them as big as 3/8"... you put both brands side by side and you'll see the differents.
http://controls.tuthill.com/Su...l.pdf
Old Feb 3, 2006 | 12:24 PM
h22 civic's Avatar
i tried to buy this linkage bout 2 years ago 1 big run around but from what i remember they where like 400-500 you had to remove the passenger seat permanletly and the heater core had to come out i had pics bu got to look let me know what ya come up with
Old Feb 6, 2006 | 10:55 AM
tony1's Avatar
Default Re: Avid rod shift linkage for the H-series. (h22 civic)
Just got a catalog from a company I talked to at PRI about cables like this for a K series all motor car. http://www.ringspann.com They say they've worked with Formula 1, Champ cars, IRL, Big Foot lol, and various drag cars. They supplied the shifter cables to Ford for the Ford GT project. I'll assume their stuff is good! lol
Old Feb 6, 2006 | 11:20 AM
Drag Race Inc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just got a catalog from a company I talked to at PRI about cables like this for a K series all motor car. http://www.ringspann.com They say they've worked with Formula 1, Champ cars, IRL, Big Foot lol, and various drag cars. They supplied the shifter cables to Ford for the Ford GT project. I'll assume their stuff is good! lol</TD></TR></TABLE>
Pass on the info, I am game to try it.
Old Feb 7, 2006 | 06:19 AM
93H22ACX's Avatar
Default Re: Avid rod shift linkage for the H-series. (CDR)
good thread
selfmade209
Transmission & Drivetrain
May 11, 2009 09:59 PM
stegon78
Jun 24, 2005 08:46 AM
Aespooncivic
May 7, 2005 09:23 PM
B_1_8_hatch
Feb 23, 2004 03:47 PM
Raxx
Jul 12, 2003 03:37 AM
