Need some sugestions....
Old Feb 2, 2006 | 03:46 PM
h2392si's Avatar
Default Need some sugestions....
Hey peeps, i got a 98 ex coupe and when i start to brake it shakes like crazy. The steering wheel shakes and the whole car starts to vibrate. What could it be?? Rotors, axles, alignment? Any help would be appreciated.
Old Feb 2, 2006 | 03:55 PM
Voyage34's Avatar
Default Re: Need some sugestions.... (h2392si)
I had a warped rotor and it caused about what you described, I'd check that first
Old Feb 2, 2006 | 06:42 PM
forcefedferio's Avatar
Default Re: Need some sugestions.... (Voyage34)
sounds like rotors, if they will still be within specified thickness you can have them cut on a brake lathe, if not you will have to replace them...does it shake in just the steering wheel or do you feel it in the seats? general rule of thumb is if you feel it in the seats its the rear and steering wheel is up front.
Old Feb 3, 2006 | 01:32 PM
h2392si's Avatar
Default Re: Need some sugestions.... (1jdmferio)
mostly the steering wheel. Any good brands you peeps recommend.
Old Feb 3, 2006 | 03:04 PM
Voyage34's Avatar
as 1jdmferio mentioned, if theyre within the acceptable thickness range you can have them recut, most anywhere that does brakes can do that for you.
if the rotors are too worn you can get replacement rotors for around 30 bucks depending on brand, ive got brembo blanks and they work great for me, those were a bit more expensive around 60 if i recall
Old Feb 3, 2006 | 04:02 PM
tallyturbo's Avatar
worped rotors gets my vote
Old Feb 6, 2006 | 09:24 AM
h2392si's Avatar
Default Re: Need some sugestions.... (tallyturbo)
thanks everyone.
Old Feb 6, 2006 | 09:25 AM
the soL that could's Avatar
if it happens only when you brake... it has something to do with the brake components i believe. and i'm ^^^^^ sure it's the rotors that are warped.
7panget
11
Apr 29, 2008 12:02 PM
skn181
Jul 1, 2007 06:45 AM
teletekman
May 3, 2006 09:15 AM
redteg1
Apr 1, 2004 11:24 PM
98ITR681
Jun 27, 2003 12:06 PM
