Pulling out Cluster?
Old Feb 2, 2006 | 03:42 PM
EJay1's Avatar
Default Pulling out Cluster?
Does Any1 know how to remove the cluster, I need to replace some bulbs and Im not really sure how to get back there. Or should I just go start ripping things off haha
Old Feb 2, 2006 | 03:44 PM
suprmods's Avatar
Default Re: Pulling out Cluster? (EJay1)
undo the 4 screws holding in the black trim around the cluster, then remove the 4 screws holding the cluster to the dash. Pull it out a bit and try to get to the wires in the back to undo them. It should pull right out.
Old Feb 2, 2006 | 04:02 PM
Top-Fuel's Avatar
Default Re: Pulling out Cluster? (suprmods)
ya there are just few screws, very simple but once you get the screws out, it may feel tough to pull out the cluster but dont' be scared that you might break something. Cause I had that problem but check the HELM'S manual to make sure and it was fine. Just give it a good yank after once you get the screws out.
Old Feb 2, 2006 | 04:04 PM
hondaboy4life's Avatar
is this for a eg? if so start by removing the big plastic trim peice aroundit that has the vents in it. 1st remove the hazard switch using a flat head screw driver to pry it out. then theres a screw in the top left corner under where the hazard switch used to be. Then remove the two screws that are above the cluster their on that lip on the top of your dash. Their facing upwards. Then u just gotta pry and pull that plastic peice off. then do what the previous poster said.
Old Feb 2, 2006 | 04:38 PM
EJay1's Avatar
Yeah I got everything out its just the dash piece is being held back by the clock and the hazards but I guess they can be pryed out with a flat head? Gonna go try it, and yeah its for a EJ1
Old Feb 2, 2006 | 04:45 PM
BauleyCivic's Avatar
Risky Business
Default Re: (EJay1)
https://honda-tech.com/zerothread?id=661308
Old Feb 2, 2006 | 05:13 PM
3.point.2's Avatar
Default Re: (EJay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJay1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I got everything out its just the dash piece is being held back by the clock and the hazards but I guess they can be pryed out with a flat head? Gonna go try it, and yeah its for a EJ1 </TD></TR></TABLE>
both can be pryed out and the unplugged. once those are out and the screws from the black trim are out you can pry it out. then unscrew the 4 screws in the cluster and pull it out.
Old Feb 2, 2006 | 05:58 PM
EJay1's Avatar
Ok so i got it out, replaced the bulbs i needed. Screwed it back in but now the needles arent working. It doesnt show it idel'ing or anything.
Old Feb 2, 2006 | 07:14 PM
frog37_'s Avatar
Default Re: (EJay1)
Bet u forgot to plug something in
now you get to tear it all apart again -
ive been there
Old Feb 2, 2006 | 08:22 PM
EJay1's Avatar
No everythings plugged in, gas works everything but rpms
Old Feb 2, 2006 | 08:24 PM
.Beaver's Avatar
Bloody Beaver
Default Re: (EJay1)
you probably pulled a pin out of the plug
Perfectionist
Dec 2, 2006 12:52 PM
tuan...
Oct 27, 2003 04:28 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
Petah
Apr 15, 2002 04:35 AM
