buzzing GSR? PLEASE HELP
Old Feb 2, 2006 | 02:57 PM
p-p-porkchop's Avatar
Default buzzing GSR? PLEASE HELP
BUZZZZZ. This is what I hear everytime i start my engine. It only happens everytime the engine is started and stops after 5 seconds or so. A mechanic told me it was coming from the ABS and that the car should be fine.
Has anyone experience this problem? I have a 1995 GSR.
My car also makes that rattleling can noise at 3500 RPM and someone already told me that the noise was caused by the A-pipe and that replacing the headers would eliminate the noise. Correct?
PLEASE HELP
Old Feb 2, 2006 | 03:26 PM
GSRintegra_Bob's Avatar
Ihe buzzing sound is in your ABS unit, it happened on both my gsr's and i dont think it creates a problem what so ever. And your rattle is probably a heat shield somewhere. I have all my heat shields off and no rattle. Its a common problem from what i know. Hope this helps.
Old Feb 2, 2006 | 03:45 PM
92integraVTECgsr's Avatar
Default Re: (GSRintegra_Bob)
what's rattling on the ABS? cause mine is doing the same thing. everytime i start the car it rattlers, then goes away if i rev it up or start driving for 5-10 seconds.
Old Feb 2, 2006 | 04:00 PM
Default Re: (92integraVTECgsr)
thanks bob but do you know how to make that noise go away? And 92integravtecgsr, my car is more of a buzzing noise not a rattling noise. If your car rattles when you start you might wanna take at the heat shield like bob said. As for my ride it makes a rattling noise at 3500-4000 RPM. I am told that this happens to many integras and that replacing the headers would help.
Anywho how do I make that buzzing from the ABS go away? Do i need to replace something?
Old Feb 3, 2006 | 03:28 PM
LSracing94's Avatar
Default Re: (jdmdc2jdm)
replacing your header will get rid of the annoying buzzing sound that i dealt with for months. i know exactly what you are talking about
Finger Lickin' good
Nov 23, 2005 04:30 AM
mugen_gangster
Aug 5, 2005 09:08 PM
1992gsrb17
Mar 24, 2004 03:00 PM
1992gsrb17
Mar 23, 2004 12:21 PM
JimmieD
Feb 22, 2002 03:31 PM
