Turbo
Old Feb 2, 2006 | 02:31 PM
plattapus's Avatar
Default Turbo
I have a 97 integra type r. I was looking to put a turbo on it. Which turbo should i go with that is realiable and not more than 3500 on a kit? Or should i go with buying parts individually? any suggestions?
Old Feb 2, 2006 | 02:48 PM
Haleiwa-Brando's Avatar
Default Re: Turbo (plattapus)
What # is your 1997?
There are a few of us here that have had or currently are turbo charged. This is including myself.
I'm sure Chris F, Jordo, Dr. Pooface will chime in soon. I'll respond when I get home from work.
Welcome to the boards!
Oh yeah...post pics of the R!
Old Feb 2, 2006 | 02:52 PM
Opie's Avatar
I suggest you weigh out the costs and benefits of turboing your ITR. If $3,500 is your budget prepare to break it in the near future.
Old Feb 2, 2006 | 02:55 PM
Jon D's Avatar
if your budget is $3500, id save giving your money away to a shop and just go ahead and take a sledge to your motor! At least that way you can start on the rebuild you will have to do eventually. Best of luck with your decisions.
Old Feb 2, 2006 | 03:28 PM
white rocket's Avatar
A simple DRAG kit a low boost would do fine on a stock motor. Tuning is where the problems arise. Choose your engine management wisely and talk to a shop you know and ask thier opinion.
Good tune = safe, healthy motor / Bad tune = blown motor eventually
Your $3500 budget will be broken quickly.
Old Feb 2, 2006 | 03:35 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plattapus &raquo;</TD></TR><TR><TD CLASS="quote"> Which turbo should i go with that is realiable and not more than 3500 on a kit? </TD></TR></TABLE>
Virtually mutually exclusive!
Do not pass go, do not collect $200.
Old Feb 2, 2006 | 06:28 PM
JjuuN R's Avatar
Default Re: Turbo (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">
Good tune = safe, healthy motor / Bad tune = blown motor eventually</TD></TR></TABLE>
Good tune = safe, healthy motor, blown motor eventually / Bad tune = blown motor in the very near future
Old Feb 2, 2006 | 09:17 PM
Chris F's Avatar
Default Re: Turbo (JUN.R)
Search for posts by me, Dr. Pooface, itr206, etc...
Buy a boosted R. Sell your car. That's the cheapest way in, if you really want to go there.
What do you use the car for?
-Chris
Old Feb 3, 2006 | 03:05 AM
Dr Pooface's Avatar
Default Re: Turbo (Chris F)
$3500??? lol
Buy a civic hatch and boost that.
If you can properly boost an ITR for under $10,000 you've won.
Old Feb 3, 2006 | 03:06 AM
Dr Pooface's Avatar
Default Re: Turbo (Dr Pooface)
ps buy my car
Old Feb 3, 2006 | 05:34 AM
migs's Avatar
My car has been boosted for nearly 2 years. Still running strong *knock on wood* Wastegate is only set at 0.5bar. Compression lowered to 8.6:1 (Blitz 3mm). I believe its in the tuner and how hard you drive. Personally, I hardly drive my car hard as well as the previous owner.
FWIW, another block is already being assembled for me, just in case.
Old Feb 3, 2006 | 05:39 AM
AssPenny's Avatar
Default Re: Turbo (migs)
I think you could do a Turbo for $3500 if you do all the work yourself and get used parts. The biggest expense will be a good ECU and tuning.
Old Feb 3, 2006 | 06:50 AM
DC2R714's Avatar
Default Re: Turbo (AssPenny)
Cheapest way to make a stock ITR bottom end more reliable for turbo is a 3mm headgastket, adjustable cam gears, and a good tuned EMS. Depending on your driving and how often it will last alot longer than just a stock motor. Jeff Evans still runs his stock GSR motor with that setup at 354whp and it has been running for 3 years, and it is drag raced often.
Old Feb 3, 2006 | 08:13 AM
PM-Performance's Avatar
Default Re: Turbo (DC2R714)
IN all defense, Jeff hasnt driven that car prob since he dynoed it years ago and didn't drag race it often at all. Maybe once.
I will agree on the rest though. Get a thicker HG and some good tuning. Or keep it stock and even better tuning
marvin75
May 14, 2014 03:50 PM
8THGENCRUZE
Honda Civic (2006 - 2015)
Oct 25, 2013 10:49 PM
elrandeeto
15
Jun 22, 2005 08:03 PM
Phoenix GSR
Mar 24, 2002 06:58 PM
