97 prelude no start no spark
Old Feb 2, 2006 | 02:14 PM
chevellbill's Avatar
Default 97 prelude no start no spark
well i have replaced dizzy, replaced coil, plugs wires no shortin wires to ecm or to tach, crank position and tdc sensor right ohms no short timming is correct I believe ecm prop now where good rep place to get ecm besides honda not paying 800 dollars good compression 150 and 140 across all 4 and no signal to fire injectors
the only weird thing is water temp is maxed out
Old Feb 2, 2006 | 02:16 PM
BB6racer's Avatar
checked all your fuses too? you just need to check all your grounds and circuits until you find the problem. have you done any modifications to your car recently?
Old Feb 2, 2006 | 02:34 PM
Sabbotage's Avatar
Default Re: 97 prelude no start no spark (chevellbill)
puncuation is your friend use it so people can understand what you are saying if not it looks like a bunch of jibberish like this
Josh Mcholland
Jul 4, 2019 06:38 PM
a2dadamm
Apr 23, 2012 08:33 AM
H22a4u
Feb 3, 2006 03:30 AM
JDMBB2
Jan 22, 2004 09:23 AM
