wheres the vss vehicle speed sensor on a 88 4 door civic dx
Old Feb 2, 2006 | 01:10 PM
cjwarren4dcivic's Avatar
Default wheres the vss vehicle speed sensor on a 88 4 door civic dx
wheres the vss vehicle speed sensor on a 88 4 door civic dx i need to know where the sensor itself is
Old Feb 2, 2006 | 01:25 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: wheres the vss vehicle speed sensor on a 88 4 door civic dx (cjwarren4dcivic)
The sensor itself is in the speedometer;
The drive unit for it is in the transmission..
Somes pics of both here:
https://honda-tech.com/zerothread?id=1505300
Old Feb 2, 2006 | 01:50 PM
Default Re: wheres the vss vehicle speed sensor on a 88 4 door civic dx (88DXCRX)
which one would cause it to throw the 17 cel
Old Feb 2, 2006 | 02:28 PM
88DXCRX's Avatar
Is your speedometer working?
If not, suspect/inspect the cable.
In my case,I had to replace the instrument cluster..
Old Feb 2, 2006 | 09:44 PM
how do u test tht sensor
Old Feb 2, 2006 | 10:39 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjwarren4dcivic &raquo;</TD></TR><TR><TD CLASS="quote">which one would cause it to throw the 17 cel</TD></TR></TABLE>
A broken speedometer cable caused a code 17 in my old DA, check that first because it is the most common problem. if that is fine then check your gauge cluster next because it is unlikely that your mechanical VSS is messed up (bolts to your tranny on the transaxle, right above and inbetween your axles)
Do a search for VSS and you will find all the info you need
Old Feb 2, 2006 | 11:29 PM
how do u test if the vss in the dash is good
Old Feb 3, 2006 | 09:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjwarren4dcivic &raquo;</TD></TR><TR><TD CLASS="quote">how do u test if the vss in the dash is good</TD></TR></TABLE>
Basically by looking at it, if it works like you say it does then it is bad! The mechanical part of it is bad and needs to be replaced with a new/used unit.
Old Feb 3, 2006 | 10:50 AM
wat i meant is how do u test the electronoc piece
Old Feb 3, 2006 | 11:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjwarren4dcivic &raquo;</TD></TR><TR><TD CLASS="quote">wat i meant is how do u test the electronoc piece</TD></TR></TABLE>
the only way I know is to check it with the speedo cable attached, since it's a mechanicl speedo you can't diagnos it like electronics. If it is off with your cable hooked up then it is not working any more, the spring mechanism in the speedo is not calibrated properly anymore and cannot be fixed (that I have ever heard of anyway). Just replace it! it will fix your problem If you really want to check it you need to get a known working speedo and plug it up to see if it's still off. So again you are left with having to replace it w/ another unit.
honda.lioness
Jun 24, 2008 03:25 PM
aziaticvang
Jan 13, 2008 06:35 PM
CRX_Control
Jul 8, 2004 09:14 PM
Dent Free
May 7, 2004 08:38 AM
