90' hatch NoX levels are too high!!!
Old Feb 2, 2006 | 11:21 AM
Adern's Avatar
Default 90' hatch NoX levels are too high!!!
I can't get my hatch to pass Texas Emissions. The inspector said my NOX level was way high.
90'hatch std-Sohc-1.5L-74hp-190,000miles-Bone stock.
Can anybody give me a list of parts that may be causing this? Parts that may need replacing? I know the whole damn engine should be replaced...not ready for a transplant just yet.
Thanks guys.
Old Feb 2, 2006 | 11:29 AM
efnfast1's Avatar
Default Re: 90' hatch NoX levels are too high!!! (Adern)
retard the ign. then try again .
Old Feb 2, 2006 | 02:02 PM
Adern's Avatar
What did you call me!??...jk.
I dont know how that would help...can you explain? A few people told me it may be the cat-converter. I'm still stumped.
Thanks anyways.
Anymore ideas?
Old Feb 2, 2006 | 02:04 PM
Jester88Si's Avatar
slip him 20-40 bux works all the time .....
Old Feb 2, 2006 | 02:08 PM
Mr_CRX's Avatar
NOX usually occurs under very high combustion chamber temperatures.
Thats why efnfast1 recommended retarding the ignition timing a bit. A more advanced timing will lead to higher temps, so pulling it back by retarding it a bit should help to cool it down.
What octane are you running?
Do you have a printout showing what your measurement was, and what the allowable amount is? How much did you fail by?
Old Feb 2, 2006 | 07:44 PM
Adern's Avatar
Don't have the slip anymore...Fiance trashed it!!
I recently replaced the dizzy on it. Before I try again this is what I'll do:
-Seafoam gastank,intake,crankcase.
-Change oil,plugs,wires,cap & rotor,oil filter,airfilter,fuel filter
-adjust timing(if needed)
-replace cat-converter & install new oem exhaust-catback
-compression test
-add secret fuel cleaner...maybe.
Anything else??
Thanks.
If I fail again I'll post up the slip with #s.
Oh yeah...The car does overheat.I guess I'll check the fans and the thermo.
right?
Old Feb 2, 2006 | 08:52 PM
robx7fcna's Avatar
Default Re: (Adern)
I would have to agree with retarding the timing.
If you are going to go to the extent of outting new exh on your car, I would also spring for a new o2 sensor, as the non heated versions in the pre OBD cars dont seem to last too long from my experiances. They are cheap anyhow, prolly 30 for a bosch or somthing like that.
Like someone allready said, High NOX is caused by high combustion temps, so it could be timing related (most likely, or a lean issue, (could be likely if you have a chipped ECU and tried to lean out your fuel map for emissions (I did this and failed horribly in my NOX ))
Also, it helps to give the cat a little help in heating it up by holding a steady 2500-3000 rpm idle while you are in the lineup. Getting the cat warm will make it more efficient and burn off hydrocarbons, CO, and NOX better than if it was cooler.
good luck, Rob
Old Feb 2, 2006 | 10:56 PM
Adern's Avatar
Thanks for the advice! How do I retard the timing?
Old Feb 3, 2006 | 07:07 AM
Adern's Avatar
Old Feb 6, 2006 | 01:02 AM
didyouhearthat's Avatar
Default Re: (Adern)
Did you smog it?
I smogged mine the other day. First time, NO levels were about 100PPM too high. I think the limit was around 840 and I had around 930. I retarded the timing and went back. The NO PPM dropped around 300 points down between 500-600!
Passed!
apaige58
10
Aug 5, 2013 04:36 PM
RACEPAK
Aug 29, 2006 02:28 PM
civic_std
Jan 12, 2006 09:31 PM
trrbl1bmx
Nov 28, 2005 04:46 PM
