B16b Piston Rings
Old Mar 24, 2002 | 08:59 PM
itr0045's Avatar
Default B16b Piston Rings
Alright guys, I am looking to get some CTR pistons. My question is regarding the rings. Can I use rings from for any B series motor with the same bore (most all are the same bore right?)? Or do I need to get B16b rings. My concern is that Honda, where I get basically cost on parts, will not carry B16b piston rings. What should I do? Thanks in advance.
Old Mar 25, 2002 | 08:36 AM
itr0045's Avatar
Default Re: B16b Piston Rings (itr0045)
come on
Old Mar 25, 2002 | 08:45 AM
RyanR's Avatar
All B-series VTEC rings are the same. Like you said though, just make sure you get OS rings.
Old Mar 25, 2002 | 09:54 AM
Trey's Avatar
25 Year Member
Default Re: B16b Piston Rings (RyanR)
All B pistons are 81mm standard bore.
Over bore is 81.25mm
CRV B20 is 84mm standard bore, 84.25 overbore.
Just use the B16a rings
ziurek filmus
Apr 16, 2017 10:17 PM
zenon8890
Feb 5, 2009 06:01 PM
95blackEG
May 23, 2007 02:50 PM
SanoJDm
Mar 20, 2003 12:54 PM
