engine swap questions into 95 sol s
Old Feb 2, 2006 | 06:50 AM
JDM-Punk's Avatar
Default engine swap questions into 95 sol s
i have a 95 honda del sol s model, and looking to do a engine swap with it... im thinking about getting a gsr for 2,400... what i dont kno is how hard it is to do this swap and was wandering if anyone can lend some tips on the swap im about to embark on... i am open to other swaps also
Old Feb 2, 2006 | 03:45 PM
jdmcars.com's Avatar
Default Re: engine swap questions into 95 sol s (IknowYou)
It's a simple swap. You will need to purchase a shift linkage (GSR nor your stock one will work).
Do a search -you will find many write ups on it.
But in short -bolt GSR motor, tranny, mounts, axles in -use your stock wiring and add needed wires -get DelSol B Series shift linkage - Drive away.
Old Feb 2, 2006 | 05:07 PM
JDM-Punk's Avatar
thanks for the info... i found out today it was a gsr type R
Old Feb 7, 2006 | 08:05 AM
Default Re: (IknowYou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IknowYou &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info... i found out today it was a gsr type R</TD></TR></TABLE>
A what? You are getting a GSR or a Type R -you aren't getting a GSR Type R.
Old Feb 7, 2006 | 10:12 AM
IHateJDM's Avatar
now would be a good time to start second-guessing the integrity of your seller. there is no gsr type r, either he's lying to you, or he doesn't know any better. Neither situation makes them a good person to buy a motor from.
Old Feb 7, 2006 | 02:59 PM
K20Ej1's Avatar
Default Re: (IHateJDM)
U better off gettin a LSR it has two vtec's
Old Feb 7, 2006 | 03:59 PM
JDM-Punk's Avatar
i ment i found out today that it was comfirmed to be a gsr not a type r... i was just a tad past drunk when i wrote that, lol
Old Feb 8, 2006 | 10:39 AM
K20Ej1's Avatar
O i see, Drunk, my bad for the dumb coment i understand now
Old Feb 8, 2006 | 10:47 AM
K20Ej1's Avatar
Default Re: (SPOONedEJ1)
But anyways the motor swap drops right in if u have everything with it, depending on what year the motor is, If its an OBD1 motor u are good plug and play everything will work besides Vtec wich u will have to wire up/ pin to ECU, and a knock sensor for no check engine light. Also U might wanna get a GSR trottle cable and replace urs so it will fit nice and reach. O yeah and the shift linkage will have to be cut and welded or the betterway is to buy a Del Sol Bseries shift linkage
Old Feb 8, 2006 | 02:53 PM
carma42's Avatar
and what if it's an obd 2 motor can he still use it? if not why?
Old Feb 8, 2006 | 04:08 PM
JDM-Punk's Avatar
thanks, for the info... i try not to get on here drunk alot... but it always happens, lol
2k3msp
Sep 30, 2008 01:17 PM
bjfisher
Jan 8, 2006 05:44 AM
Bryro22
Jul 2, 2005 08:09 PM
ez_steezy
Apr 27, 2005 11:55 AM
-_-
Jan 6, 2004 01:07 PM
