ARIAS Pistons and EAGLE connecting rod combo set ** $775.00 SHIPPED!! **
Arias Pistons and Eagle Rod combo set.
<U>$775.00 SHIPPED!!!</U>
No Drop Shipping here. All kits inspected and shipped from our shop.
B18C, B18A/B, B16A, D16, H22, K20
ARIAS Piston kit includes:
(4) Pistons
(4) Wrist Pins
(4) Piston Ring set
(4) Pin locks
(1) Piston spec sheet
Eagle Connecting Rod set includes:
(4) Connecting rods with ARP Rod Bolts
(1) Moly Lube
<u>Common piston compression choices:</u>
The kits below are just some of what ARIAS offers. PM or contact us if you have other bore and compression preference.
B18A/B/C
#3320202 81.5mm Turbo 9:1 compression - Inverted Dome (Dish)
#3310402 81.5mm Turbo 10.2:1 compression – Inverted Dome (Dish)
#3320900 84mm Turbo 9.2:1 compression - Flat Top
#3310000 84mm Turbo 10.6:1 compression - Flat Top
#3330402 81.5mm All Motor 12.9:1 compression - dome top
#3330511 84mm All Motor 12:1 compression - dome top
#3330700 85mm All Motor 13.8:1 compression - dome top
B16A
#3320202 81.5mm Turbo 8:1 compression - Inverted Dome (Dish)
#3310402 81.5mm Turbo 10.4:1 compression – Inverted Dome (Dish)
#3320900 84mm Turbo 8.2:1 compression - Flat Top
#3310000 84mm Turbo 10.9:1 compression - Flat Top
#3330402 81.5mm All Motor 11.3:1 compression - dome top
#3330511 84mm All Motor 10.6:1 compression - dome top
#3330700 85mm All Motor 12.3:1 compression - dome top
D16A6/Z6/Y8 and H22
contact us for available choices or check out http://www.ariaspistons.com
Other pistons kits available for:
EJ20,25
SR20
KA24
4AG
3TC
K20
and more....
Modified by exospeedAMcrx at 10:00 AM 3/4/2006
Modified by exospeedAMcrx at 11:55 PM 3/7/2006
(4) Pistons
(4) Wrist Pins
(4) Piston Ring set
(4) Pin locks
(1) Moly Lube
B18A/B/C
B16A
D16A6/Z6/Y8 and H22
EJ20,25
SR20
KA24
4AG
3TC
K20
and more....
Used by many Pro Racers! Look at the line up of successful racers using ARIAS.
ProRWD Scrantons
ProFWD Rhodes
ProFWD Bergenholtz
Hot Rod Tran
Hot Rod Del Rosario
Hot Rod Jolly
All Motor Bisimoto
All Motor Erick Aguilar
Modified Humphreys
and many more.
ProRWD Scrantons
ProFWD Rhodes
ProFWD Bergenholtz
Hot Rod Tran
Hot Rod Del Rosario
Hot Rod Jolly
All Motor Bisimoto
Modified Humphreys
and many more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xfrankx »</TD></TR><TR><TD CLASS="quote">thats a sick price imma have to come to you when i get mine here in about a month
any questions.. we're here to answer them.
