fuel cell venting question
if I have a one gallon fuel cell mounted on the firewall in the engine compartment, how important is it to run a vent line to the outside of the car? I have an RCI fuel cell that comes with a rollover vent fitting on top, will the tech inspectors make a big deal if I dont have a line running it outside?
thanks
Alex
thanks
Alex
the fuel cell in my truck just has a tip valve and a fitting on top as a vent, no vent tube, and I've never had any problems w/ tech at the track.
one difference: mine is in the bed of the truck, not in the engine bay, not sure if that would make a difference to tech inspectors or not.
the vent on top will be fine as long as the fuel cell is 6 inches from the flywheel you will be fine and grounded the only time you have to have another vent like outside the car is when its located inside the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage »</TD></TR><TR><TD CLASS="quote">great.. thanks
oh yeah, how can you legally mount it inside the car? do you have to build a steel box surrounding it?</TD></TR></TABLE>
steel or a thick gauge aluminum. it has to be completely sealed off from the drivers compartment.
Matty.
28
Jul 30, 2006 08:54 PM
