interchangeable si parts ????
Old Feb 1, 2006 | 07:30 PM
Ghett0_ed's Avatar
Default interchangeable si parts ????
hey guys i was wondering if anyone knew what parts would be interchangable without modification from an 89 si hatchback to an 88 crx si?
and i was also wondering if anyone could give me some info about motor swaps...like how hard are they the first time?
thnx in advanced
Old Feb 1, 2006 | 07:34 PM
boostinaintez's Avatar
Default Re: interchangeable si parts ???? (BlackGSRhhatch)
do some research first man and tell us your goals. But I would go with a blown small block 350 with a 400 trans
Old Feb 1, 2006 | 08:47 PM
Ghett0_ed's Avatar
Default Re: interchangeable si parts ???? (boostinaintez)
goals??
my goals are to put my motor into another car...pretty self explanitory isnt it?
and ya a 350...not quite my style...wierd huh
but thnx for the help
your input really helped me
Old Feb 1, 2006 | 09:11 PM
cr-x-91's Avatar
just about everything but the seats with some mods. as far as motor swaps, they arent that hard to do, just do ur homework and prep up. bag and lable every nutt and bolt. what engine do u plan on puttin in.
Old Feb 1, 2006 | 09:54 PM
Ghett0_ed's Avatar
Default Re: (cr-x-91)
right now i have an 89 hatch si with a 92 GSR motor but i slid into a curb like last year and messed up the frame/body whatever....so now the motor is goin into an 88 si crx...but ya the b17 is goin into the new car
Old Feb 2, 2006 | 04:32 AM
Default Re: (BlackGSRhhatch)
just for the record i wasn't serious. but shitty thing with that curb and all i hope your new project goes well. just swap everything from your other car to that one everything will work. atleast engine wise. Thats cool they are both si so you won't have to mess with the hubs, you will be alright
Old Feb 11, 2006 | 11:04 AM
Ghett0_ed's Avatar
the guy that owns the crx im about to buy hit a pole....the front is bent in quite some....are all the parts up front replacable??
like evrything in the center...the headlights are fine but the middle is curved?
Old Feb 11, 2006 | 11:09 AM
jlicrx's Avatar
they are replaceable, but you would have to weld in the radiator support - also, a lot of times when hit in the center, it pulls the frame in on each side and can bend the crossmember - a good body shop can check it and pull the frame back to where it needs to be, if needed
Old Feb 11, 2006 | 11:19 AM
Ghett0_ed's Avatar
great another bent frame ef
my other car the 89 civic also has a bent fram e i think
Old Feb 11, 2006 | 01:32 PM
Ghett0_ed's Avatar
has anyone had experiences with this?
i mean with hitting a pole and trying to redo the front?
Old Feb 17, 2006 | 01:39 PM
Ghett0_ed's Avatar
bump for some more info
geoscranny84
Mar 5, 2008 06:43 PM
Snoxxy
May 12, 2006 09:49 PM
