Honda S2000 Honda S2000
T U R B O s2K?????
Old Mar 24, 2002 | 07:07 PM
MaD3 In JaPaN's Avatar
Default T U R B O s2K?????
any good turbo kits out for the s2000 i've seen a couple but because of the high compression of the s2000 they couldn't run much boost off of it and gain that much hp's.....any after market pistons and rods for the s2000 to lower the compression too???????????
Old Mar 24, 2002 | 08:39 PM
BlazingFstS2k's Avatar
Default Re: T U R B O s2K????? (New2HD)
http://www.speed-craft.com
Old Mar 24, 2002 | 10:33 PM
kumar75150's Avatar
Default Re: T U R B O s2K????? (BlazingFstS2k)
Speedcraft puts around 335 to the wheels but cost 6grand + parts for a total near 9 grand.
Old Mar 25, 2002 | 01:01 AM
Default Re: T U R B O s2K????? (kumar75150)
I think i read somewhere it puts 334Hp to the ground with low boost (8.5psi) on stock internals. Witch means thats 8.5psi on 11:? Compression ratio... the thing is you drop some JE 9:1 compression pistons,some strong rods get the hole rotating assembly blueprinted and balanced and get the head ported and polished along with the intake manifold and most of all you upgrade your fuel system and all and get either a Hondata or Haltech stand alone and you boost away... I've heard rumors of possibly getting around 400-500Whp with 15psi... But i woulden't know i haven't delt with there setup. I myself had the comptech supercharger with a Nx express direct port 100 shot so i was making roughlt around 350-375Whp... take or give alittle...
Now my new project has came along, the M coupe, hopfully i can get things together and either turbo it or supercharge it and get up in the 500-600Hp range... But we'll see......
Old Mar 25, 2002 | 07:09 AM
so they je makes after market pistons for s2000's, what about rods who makes those for s2000's????????????
Old Mar 25, 2002 | 05:03 PM
icefire069's Avatar
They also do nice low 12 passes and kills 996 turbos
Old Mar 25, 2002 | 06:16 PM
Default Re: T U R B O s2K????? (icefire069)
I think JE can custom pistons for any applacation if i am correct. The thing is when you upgrade to that kinda power to wanna change to a better clutch and differencial and ****. Otherwise that'll be your wink link and sooner or later it'll break... But if your plans on turboing a S2k i'd say bank about 12k to do it right, thats building the bottom end and replacing the clutch ect....
Old Mar 25, 2002 | 08:59 PM
12's huh.......thas not bad, but i'm also looking at NSX, and M3's......the turbo kits for them are expensive as hell, like 9 gz........and they both make those cars hit 12's...........but the wrx has a $4800 power package that makes it hit the same times, 12's for cheaper price on the turbo and the car, i dunno.... i'm coming back in a few years leaving for germany at august and don't know what car to get when i come back, so far it's s2000, like a 97-99 nsx, brand new m3, or the 2002 wrx brand new.......they all have there pluses and downfalls, just don't know though, i'm pretty partial on the m3 and nsx's just because what they are, but still undecided............
Old Mar 26, 2002 | 03:38 PM
integrate's Avatar
They also beat Z06s
Old Mar 31, 2002 | 12:38 PM
Default Re: T U R B O s2K????? (integrate)
hey blazing fast s2k, how did that 100 shot direct port and supercharger go with eachother, i heard it was kinda dangerous to mix those 2 especially 100 shot direct port man.......i bet that hauled, but i would be afraid of detonation..........
Old Mar 31, 2002 | 01:31 PM
HondasRfast's Avatar
From: Alexandria, Louisiana, United States of Arabia
Don't waste your time with nitrous, all its gonna do is **** your engine up. Comptech makes a supercharger that puts out like 350 HP, and it helps with the low end problem Honda seems to have.
Old Mar 31, 2002 | 01:37 PM
integrate's Avatar
Default Re: T U R B O s2K????? (HondasRfast)
Not really.
Old Mar 31, 2002 | 01:44 PM
12.30'sser's Avatar
why do you guys always want to lower the compression ratio? i dont understand this. here's the deal high compression turbo is the ****. all you have to have is a stand alone and someone that knows what they are doing tuning it. st00pid is the one that tunes all the fast cars in houston. just for ***** and grins we built an 11.5 to one motor (yes it was built) and ran 24 pounds of boost on it. on 119 of course. running ten pounds of boost on a stock s2000 motor should not be hard with the high compression. as long as you have a stand alone. put in a little race gas and turn the boost up. we run 20 pounds all day in my ls turbo on pump gas. no problems. im talking all day. i drive this car an average of 100 miles a day. and i dont baby it. so its all in the tuning guys. its all in the tuning.
Old Mar 31, 2002 | 02:47 PM
SpoonCivic's Avatar
New User
Default Re: T U R B O s2K????? (12.30'sser)
not everyone has access to race gas 24 hours a day...
Old Mar 31, 2002 | 05:18 PM
Default Re: T U R B O s2K????? (SpoonCivic)
There is a gas station within 5 miles of my house that sales 118 octane and a airport about 30 minutes away so if needed i have access to it..
I have used the nitrous once with the Comptech kit, but i was only spraying a 50 shot at the currect time, put it this way when the sweet spot kicked in at around 6000-6500 and then the nitrous introduces it's way into the heart of the motor it took off like a bat out of hell... But yeah i got rid of the car right after hooking the 100 shot up. i rode in it with the new owner and he sprayed it and it put me back in the seat pretty good..
Maybe you should read some test results. Scc test the Comptech kit and it only improved the top end enough to shave like .2 seconds off the 0-60 " i think it was"
But to get to the chase on this topic the supercharger did improve the bottom end to much, it made way for one hell of a super Vtec...
Old Mar 31, 2002 | 05:47 PM
so it was pretty safe huh.......especially running a 100 shot direct port????? so what about the nsx's comptech supercharger u think tha'll go good with a hundred shot direct port too with it's stock internals?
Old Apr 2, 2002 | 11:58 AM
Mike K's Avatar
Topspeed Performance in Naples, FL just did a custom turbo set-up for a customer out of Miami. I don't know all the specifics, but it's a T3/T4, forget what trim..
Spearco intercooler, HKS BOV, custom turbo manifold made in-house, etc.
Real trick. The thing ******' hauls ***. Any more info, call up there and ask for Josh or Chris. (239)514-7008
Old Apr 2, 2002 | 08:55 PM
Kengs's Avatar
Default Re: T U R B O s2K????? (Mike K)
OS Giken makes custom forged pistons...
Amuse S2K turbo
Hypertune (Australia) S2K turbo
[Modified by kengs, 12:56 AM 4/3/2002]
Old Apr 2, 2002 | 09:49 PM
GokuSSJ4's Avatar
Default Re: T U R B O s2K????? (kengs)
looks good!
Old Apr 3, 2002 | 03:26 PM
redteg1's Avatar
Default Re: T U R B O s2K????? (Spoon1)
omg how fast is that s2k??
Old Apr 3, 2002 | 05:41 PM
Nick H's Avatar
New User
Default Re: T U R B O s2K????? (redteg1)
fockin fast!
Old Apr 9, 2002 | 06:39 PM
Mase's Avatar
I would never let speed craft touch my car, granted they do some good work with the welder, but some of the guys have **** for brains. very over priced, and they were even boneheaded enough on my buddys car to mount an inline fuel pump underneath the car right by the rear tire, and this being a very slammed to the ground car. on top of that, the fuel pump was bad "brand new" as they say, it squeeled like a rabid cat, they said it was just a noisy inline pump, after many phone calls and visits, they finally ordered him a new fuel pump. anyways, like i said, i wouldnt trust them.
Old Apr 9, 2002 | 07:33 PM
AllMotorITR's Avatar
New User
Default Re: T U R B O s2K????? (CDooMe2)
Damn guys, quit posting about this! You are making me want to sell the R for an S2K!
Old Apr 12, 2002 | 09:44 AM
NONKonformyst's Avatar
uh.... WOW
drool
Old Apr 12, 2002 | 02:27 PM
hybridgen2's Avatar
New User
Default Re: T U R B O s2K????? (95redLUDE)
