which motor mounts?
hey guys. the motor mount bushings on my 97 gsr r going bad. the 2 lower torque mounts r definately trashed and even though i can't see it, i think the rear mount is bad because i've been going through axles a lot recently and the rear mount is the only thing that hasn't been replaced. my question is, should i go with oem bushings or should i use the energy mount inserts? the way i understand it, the energy mounts r just new bushings in the oem mounts right? now i know that since my car only has i/h/e and type r tranny/exedy clutch/exedy flywheel that i don't really need the energy bushings right now, but would it be a worthwhile investment to go ahead and install them anyways? also, has anyone tried the shifter bushing kit? i was also considering installing that at the same time. thanx guys.
spcrxracer
Dec 29, 2013 08:10 AM
spcrxracer
Aug 20, 2012 07:34 PM
