Blown Fuse
Old Feb 1, 2006 | 02:33 PM
darksephiroth's Avatar
Default Blown Fuse
Hi, I've had consistent problems with my fuse being blown on my '04 Accord LX Sedan. Twice I have plugged in a car charger, and when i pull it out, the head gets stuck and the fuse gets blown. The two car chargers were different items, it seems like the car charger spot in my car is too small and doesn't let anything out of it. It happened with both slots, the one out on my dash, and the one inside the box under the armrest. I am wondering what fuse I have to acquire to replace the blown one, and whether or not the problem is with my car ... ThankS!
-chill
Old Feb 1, 2006 | 03:00 PM
P_Adams's Avatar
Default Re: Blown Fuse (darksephiroth)
This "Charger you're discussing, is it to charge the Accords battery; or are you driving a charger for a cell phone, lap top or other.
If it's to charge the Accords Battery, do yourself a really big favor and either modify it for some large alligator clips, or buy a Charger which connects directly to the battery.
I don't subscribe the use of cigar lighters for anything else because of what you're going thru.
Whats happening here? Because of manufacturing tolerances, they make the plug on such units smaller than it needs to be (so that it will fit everything), thus the 'loose' observation. As you pull the plug out, it rocks in the bore, touching the center contact to to case, causing the blown fuse.
P
Old Feb 1, 2006 | 03:32 PM
Ross 2.0's Avatar
In a Junkyard near you.
It's fuse # 9 15A in the under dash fuse box.
Easy tip and I know it sounds stupid, but don't use the chargers of that style. Or make sure you have a good brand name (the of your product to be plugged in). That usually helps.
Old Feb 1, 2006 | 07:07 PM
92ehatch's Avatar
Default Re: (MooGoCow3)
my moms 04 lx does the same thing. they are way to tight.
her phone charger works in my car fine, in her's it is SOOOO TIGHT
Old Feb 2, 2006 | 01:47 AM
Yeah, the first charger I plugged in was just for my Sharp GX32 Cell Phone. The second one was for interior lights. So, I'm assuming there are more than a couple people who are having this problem? Thanks for the fuse tip, moogocow3, you can buy that type of fuse at a place like fry's or something, right?
Old Feb 2, 2006 | 06:30 AM
cdsquad.net's Avatar
Default Re: (darksephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darksephiroth &raquo;</TD></TR><TR><TD CLASS="quote">you can buy that type of fuse at a place like fry's or something, right?</TD></TR></TABLE>
Any auto or hardware store.
rlh781
Honda CR-V & Element
May 2, 2018 07:10 AM
niceprelude
Sep 2, 2011 06:58 AM
ttcheung97
Dec 5, 2009 04:49 PM
Mychal71
Sep 10, 2006 02:01 PM
mugenhatch92
Sep 30, 2004 05:01 AM
