ebrake light comes on.. sporadically
Old Feb 1, 2006 | 01:24 PM
abda53's Avatar
Default ebrake light comes on.. sporadically
ever since i changed the FRONT brake pads.. my ebrake light would come on.. even if it wasnt engaged..
sometimes it wont come on.. sometimes itll come on only after driving alittle..
the ebrake itself still feels tight, and works good.. not like the cable is loose. not sure what happened..
is this a common problem in ITRs?
btw i have a 2000
Old Feb 1, 2006 | 01:30 PM
AssPenny's Avatar
Default Re: ebrake light comes on.. sporadically (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">The brake light will come on also if you are low on brake fluid.</TD></TR></TABLE>
Check your fluid level.
Old Feb 1, 2006 | 01:41 PM
Swell_Ryder's Avatar
Default Re: ebrake light comes on.. sporadically (abda53)
I believe this issue is common with Type R's and it usually hits the board when the temperature drops. Try searching and I know you will find some more info on this topic......
Old Feb 1, 2006 | 01:50 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: ebrake light comes on.. sporadically (Swell_Ryder)
add fluid.
Old Feb 1, 2006 | 02:07 PM
abda53's Avatar
thanks.. ill check out the fluid level..
you guys rock
Old Feb 1, 2006 | 02:10 PM
Skelly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swell_Ryder &raquo;</TD></TR><TR><TD CLASS="quote">I believe this issue is common with Type R's and it usually hits the board when the temperature drops. Try searching and I know you will find some more info on this topic...... </TD></TR></TABLE>
mines been doing it all winter. I guess what would explain it
Ed 341's Avatar
Default Re: (abda53)
This can also be the guage in the brake fluid reservoir. I think the floatation material looses its "floatiness" after awhile.
Old Feb 1, 2006 | 02:46 PM
Dave_B's Avatar
Another point to note is the float sensor. Sometimes it get's stuck. Jiggle it a bit if the fluid level is ever on par and you still get the light.
Old Feb 1, 2006 | 03:33 PM
abda53's Avatar
thanks ill check both today..
i did notice that on the way home, the light was on, but after it warmed up and i pushed the car more, the light went off
Old Feb 4, 2006 | 09:56 PM
abda53's Avatar
checked the brake fluid.. looks alittle low, so thats probably what it is.. ill change it tomorrow sometime.
thanks everyone
Old Feb 5, 2006 | 08:45 AM
abda53's Avatar
Default Re: (neo_)
sorry.. thats what i meant lol
jowy
Mar 14, 2005 05:52 PM
Project91CRX
14
Apr 26, 2004 03:47 PM
LSintegra
Apr 13, 2004 08:01 AM
Understeer
Dec 1, 2003 09:40 PM
vtec-izm
Aug 26, 2003 11:53 AM
