BRAKE PROBLEM HELP
ok my car start not what to stop i would have to pump millions of times to stop
ok i thout it was front brake pad were low so i replaced them
and work grate for a 1 day now it getting worst!!! i had to use ebrake to stop!!!
i need to knwo what to change!!!
passanger side works more than driver so when stoping it try to go right
need HELP ASAP
need HELP ASAP
before posting you shouldve given us this info...When you push the brakes, do you have to floor your foot? if so, then tehre's a leakage. I dont quiet remember the name of that part but its like a spiderwhich is behind the engine attached tot he back wall. Check for any leakage under your car.Those spider thingies go bad and when there's a leakage you have at least 2-3 days until you're brake fluid is gone.
ThagAnderson
Jun 28, 2007 12:41 PM
UnrealSpeed
May 17, 2003 01:45 PM
dnt94civic
Jun 7, 2002 05:04 AM
