My heat sinks
Old Feb 1, 2006 | 11:50 AM
RCautoworks's Avatar
Default My heat sinks
Thanks to Tall Kyle, I got these for free.
Should help control warpage.
Old Feb 1, 2006 | 12:01 PM
TurBros's Avatar
If you weld it right the flanges should'nt warp at all and there is no need to bolt it down. If it works for you though, thats great!
Old Feb 1, 2006 | 12:07 PM
Default Re: (TurBros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBros &raquo;</TD></TR><TR><TD CLASS="quote">If you weld it right the flanges should'nt warp at all and there is no need to bolt it down. If it works for you though, thats great!</TD></TR></TABLE>
Weld right ? Explain more
Old Feb 1, 2006 | 12:09 PM
beepy's Avatar
You must tell me this secret. My flanges always tend to bow because the the pipes shrinking after welding.
Old Feb 1, 2006 | 12:29 PM
legendboy's Avatar
Default Re: My heat sinks (90blackcrx)
nice, good idea. i use a turbine housing and cylinder heads
Old Feb 1, 2006 | 01:05 PM
*Boostwerks*'s Avatar
Thats exactly what I did.
1/2" aluminum plate drilled just like that
Old Feb 1, 2006 | 01:14 PM
david@didrace.com's Avatar
You're on crack. If the soldering iron works for you though.
Old Feb 1, 2006 | 01:28 PM
JG-Fabrications's Avatar
Default Re: (backpurge)
NICE FLANGES
-James @ JG-Fab.com/BmCRace.com
Old Feb 1, 2006 | 01:35 PM
splitime's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Thats exactly what I did.
1/2" aluminum plate drilled just like that</TD></TR></TABLE>
AL plate? From my understanding... 1/2in will warp... even 1/2in steel can sometimes be to thin. I wonder if the conductive properties of AL will help compensate though.
Old Feb 1, 2006 | 01:51 PM
Default Re: (splitime)
I use 1/2" AL plate as jigs for headers too . Never had a warped flange and the AL is still flat using a straightedge to check it.
Old Feb 1, 2006 | 02:10 PM
tony1's Avatar
If you weld 1/4" at a time and let it cool then it might not warp w/o a fixture. lol
Old Feb 1, 2006 | 02:22 PM
ManBearPig4silly's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HI! I think I'm smart! &raquo;</TD></TR><TR><TD CLASS="quote">If you weld it right the flanges should'nt warp at all and there is no need to bolt it down. If it works for you though, thats great!</TD></TR></TABLE>
JB weld is not welding little buddy
Those plates look sweet man. Post up some results now Maybe I'll get off my *** and make some. Yeah probably not going to happen.
Old Feb 1, 2006 | 02:23 PM
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">If you weld 1/4" at a time and let it cool then it might not warp w/o a fixture. lol </TD></TR></TABLE>
Key words right there
Old Feb 1, 2006 | 05:45 PM
HamiltonRex's Avatar
Default Re: (90blackcrx)
It appears my manifold was tacked to a bench/plate in several spots when welding?
Is this method acceptable also?
Old Feb 1, 2006 | 05:55 PM
TrueNorthStar's Avatar
Default Re: (HamiltonRex)
copper would work even better
Old Feb 1, 2006 | 06:11 PM
jon volk's Avatar
Default Re: (TrueNorthStar)
I usually try and weld it while bolted to a head.
Old Feb 1, 2006 | 06:56 PM
damnraz's Avatar
I brought an equal length manifold to work knowing that my flange was warped, checked it w/ a straight edge and checked it on the table, a co-worker told me that the flange needs to be bolted down to a plate to control warpage while welding so I basically took it to m disc grinder and made sure it was flat. It had about .030 gap on the each side
Old Feb 1, 2006 | 08:11 PM
TurBros's Avatar
You just have to move fast, let it cool and weld one side of the runner to the head flange and then switch sides. I promise I have made many manifolds and none of them have warped using my method.
Old Feb 1, 2006 | 08:39 PM
S2KP's Avatar
Default Re: (k20 jon)
same method I use. Fine a donor head
Those plates are pretty sweet tho
Old Feb 1, 2006 | 10:59 PM
TallKyle's Avatar
Default Re: (PANG)
anyone need plates contact me. I can make more.
i can't wait for my ram manifold to be complete
2ndGenREX
Jan 31, 2006 10:13 AM
crxsi8
Dec 16, 2005 09:52 PM
Want2race
26
Mar 16, 2005 04:11 PM
Acc91ord
Apr 18, 2004 11:40 AM
bradykiller
Aug 31, 2003 10:21 AM
