check this out... does this part go bad?
Old Feb 1, 2006 | 10:10 AM
the soL that could's Avatar
Default check this out... does this part go bad?
i believe it's the PVC chamber that i circled in the picture. does it ever need to be changed?
Old Feb 1, 2006 | 10:13 AM
Brodie Bruce's Avatar
Default Re: check this out... does this part go bad? (revelation)
Yeah, its for PCV. I have never heard of one going bad but I am sure it could happen. Why do you suspect that it might be bad?
Old Feb 1, 2006 | 10:18 AM
jdmcars.com's Avatar
I've seen the o-ring leaking behind it mostly.
It can get clogged -however it would mean that the car is really probably junky.
Old Feb 1, 2006 | 10:29 AM
IHateJDM's Avatar
Default Re: check this out... does this part go bad? (jdmcars.com)
if you think its causing a problem, replace it with a catch can
hondafixer
Sep 11, 2009 06:15 AM
lude98SH
Oct 21, 2007 03:35 PM
SNsLude
Jan 26, 2006 07:08 PM
deanh8
Nov 22, 2005 08:46 PM
