car gauges going crazy
Old Feb 1, 2006 | 08:58 AM
DA jeshy's Avatar
Default car gauges going crazy
my temp, fuel, brights, blinkers and my on dash clock will get really dim/flicker when i get at high rmps or letting my clutch slow me down or shifting. anyone know whats going on and what do i need to fix it?
and when ever my subs hit my headlights get dim.
Old Feb 1, 2006 | 09:04 AM
djtsmith007's Avatar
Default Re: car gauges going crazy (jeshy)
Your headlights dim with the subs cause the amp is drawing ALOt of power from the battery, since eveything electrical runs off the battery headlights, will dim. Get a good capacitor, and that will fix the stereo problem
As for the gauges messing up....if you have done recent work in the dash id would be a good idea to go check all the connections in the rear of the cluster...but thats pretty weird. so check any wires you might have moved or touched just to check. Good luck
Old Feb 1, 2006 | 09:07 AM
DA jeshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtsmith007 &raquo;</TD></TR><TR><TD CLASS="quote">As for the gauges messing up....if you have done recent work in the dash id would be a good idea to go check all the connections in the rear of the cluster...but thats pretty weird. so check any wires you might have moved or touched just to check. Good luck </TD></TR></TABLE>
everything has been done in the shop when it went into the shop, should i take it in and tell them?
Old Feb 1, 2006 | 10:52 AM
teg luver17's Avatar
sounds like you might need a new alternator.
Old Feb 1, 2006 | 12:02 PM
Default Re: car gauges going crazy (teg luver17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeshy &raquo;</TD></TR><TR><TD CLASS="quote">
everything has been done in the shop when it went into the shop, should i take it in and tell them?</TD></TR></TABLE>
Yes you should, because if it worked fine b4 hand, its somthing they did, accidently.
crxaddikt
Jul 5, 2012 10:08 AM
eghatchneeded
11
Nov 9, 2008 07:05 PM
friedn00dles
Oct 10, 2007 01:07 PM
ablack934doorcivic
Audio / Security / Video
Sep 18, 2004 06:15 PM
conesmasher
Mar 4, 2004 08:14 PM
