88 ACCORD SERVICE BULLETIN HUNT..
Old Feb 1, 2006 | 08:28 AM
JWEITEN's Avatar
Default 88 ACCORD Service bulletin hunt
Hi, and thanks in advance. I am searching for 2 service bulletins
that apply to my 88 Accord. The tsb numbers are:
94025 and 88013
thanks
Modified by JWEITEN at 7:51 AM 2/2/2006
Modified by JWEITEN at 8:24 AM 2/2/2006
Old Feb 1, 2006 | 03:57 PM
Ross 2.0's Avatar
In a Junkyard near you.
As infuriating as all caps is to read i'll try to help.
I need your VIN # to help out
88-013
SYMPTOM
Steering wheel vibration while the car is idling in
“D3” or “D4.”
AFFECTED VEHICLES
Up to the following VINs, replace: (need VIN)
Rear Engine Mount
Up to the following VINs, install need VIN)
Vibration Clips
94-025
SYMPTOM
The steering wheel oscillates, or shimmies, when
driving between 58 and 62 mph. It may be most
noticeable on smooth roads, and may vary with
slight steering inputs.
PROBABLE CAUSE
An imbalance of the wheel/tire/hub/disc assembly
in the front end.
CORRECTIVE ACTION
Dynamically balance the wheel and tire assembly
off the car. Then, if necessary, use the Hofmann
Finish Wheel Balancer to balance the
wheel/tire/hub/disc assembly on the car.
Old Feb 1, 2006 | 08:01 PM
hondadude's Avatar
Default Re: (MooGoCow3)
He wanted to 'SHOUT' to force a response.
Old Feb 1, 2006 | 08:56 PM
Slats's Avatar
Default Re: (hondadude)
My first Honda was an 88 Accord LX 5-speed. "gill" was a great car...had about 187K miles when I sold it.
Old Feb 2, 2006 | 06:17 AM
JWEITEN's Avatar
Sorry for the caps!
The vin is JHMCA5635JC814815
Thanks
Old Feb 2, 2006 | 06:24 AM
v4lu3s's Avatar
RTFM
sounds like the easy thing to do on those bulletins is get the wheels balanced and check the rear motor mount.....
Old Feb 2, 2006 | 06:55 AM
JWEITEN's Avatar
Default Re: (v4lu3s)
balancing front tires (wheels off vehicle) is not a definite fix....
if i had a buck for every time i balanced the tires to stop this steering
wheel from oscillating at 60 mph i'd be rich.....
as for the steering wheel shake at idle-i want to be sure the mount is the fix
Mike052
10
Jan 13, 2012 04:53 AM
hb_guy
Jul 24, 2008 03:20 PM
vietherbs
Apr 20, 2006 11:28 PM
tsdenny
Aug 7, 2004 06:44 PM
