d16y7 injectors = d16a6 injectors?
Old Feb 1, 2006 | 08:23 AM
andrey320's Avatar
Default d16y7 injectors = d16a6 injectors?/civic/crx injectors interchangable?
I have a small fuel leak from a fuel injector on my stock crx si. Since I will be pulling the injectors, I want to have them blueprinted, cleaned... with no down time. I have a d16y7 manifold laying around.
Will these injectors work on my crx? ( I understand that there may be some problem with OBD-0/OBD-2)
Are they the same flow rate?
Thanks
Modified by andrey320 at 10:14 AM 2/1/2006
Old Feb 1, 2006 | 08:29 AM
crxnj's Avatar
Default Re: d16y7 injectors = d16a6 injectors? (andrey320)
Those injectors are saturated, so to use them on your car, just remove the resistor box..
Old Feb 1, 2006 | 08:32 AM
bagpipe goatee's Avatar
well, you can't just "remove" it, you have to solder the wires together or get a jumper plug.
they are the same flow rate, though.
Old Feb 1, 2006 | 08:34 AM
crxnj's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">well, you can't just "remove" it, you have to solder the wires together or get a jumper plug.
they are the same flow rate, though.</TD></TR></TABLE>
Yes you have to solder the wires together.I should have specified,sorry..
andrey320's Avatar
Ehhhh...
I'll just buy some crx injectors.
Are all crx/civic hf,dx,si,std,dx... injectors the same?
Anyone got some?
Old Feb 1, 2006 | 08:51 AM
crxnj's Avatar
Default Re: (andrey320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrey320 &raquo;</TD></TR><TR><TD CLASS="quote">Ehhhh...
Anyone got some?</TD></TR></TABLE>
Yeah all the same si and hf except 88-89 hf injectors,,they have a lower flow rate for some reason..The dpfi injectors are different.
Old Feb 1, 2006 | 09:08 AM
beyondspexj's Avatar
as far as i knew hf's were the same. when i still had my hf motor i replaced the injectors with those from an Si. any numbers on the hf injectors vs the Si injectors??
Old Feb 1, 2006 | 11:07 AM
fourthgenhatchB17's Avatar
I have a set I pulled off a running 91 SI. PM me with an offer
Check the MPFI link in my sig.
Old Feb 1, 2006 | 12:11 PM
andrey320's Avatar
where in Ca are you?
Old Feb 1, 2006 | 02:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrey320 &raquo;</TD></TR><TR><TD CLASS="quote">where in Ca are you?</TD></TR></TABLE>
PM'd.
lshatch59
Jan 7, 2007 08:01 AM
91preyludesi
Dec 26, 2006 06:25 PM
Manny86
Nov 7, 2006 03:55 PM
carlip
Apr 13, 2005 05:09 AM
xmd
Sep 27, 2003 12:56 PM
