Fourth Generation Rotor Question.
As some of you know, the rotors on the fourth gen' VTEC Preludes were slightly larger than the Si rotors.
My question is, are the VTEC rotors applicable with the Si brake setup?
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HooTeNannY »</TD></TR><TR><TD CLASS="quote">To use the VTEC rotors you need the VTEC calipers and caliper brackets (this is for the front brakes only since the backs are the same).</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi »</TD></TR><TR><TD CLASS="quote">I'm sure this was implied, but you will also need the VTEC pads to go with those calipers.</TD></TR></TABLE>
learned the hard way a long time ago........cuz im a dumbass
if you are doing a vtec si swap then the vtec rotors are not necessary.. I bought some Axxis Ultimates and Brembo blanks and they stop on a dime. I bet they out perform the vtec setup by far.....
