Spoon Header? 4-1? 2.5"?
iv been looking at the spoon sports header
now for some i thought they also came in 4-1 and 2.5" flange
but i just did a search and all i found was 4-2-1 with 2.25" flange
am i crazy or do they come 4-1 2.5" flange?
Im not aware of a Spoon 4-1 for B-series (I could be wrong).
The Spoon 4-2-1 for ITR application is 2.5" though. I know there are a couple other Spoon headers (including a 2 piece) but I think they are all 4-2-1 designs with 2.5" collector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Im not aware of a Spoon 4-1 for B-series (I could be wrong).
The Spoon 4-2-1 for ITR application is 2.5" though. I know there are a couple other Spoon headers (including a 2 piece) but I think they are all 4-2-1 designs with 2.5" collector.</TD></TR></TABLE>
Agreed this sounds correct. I don't remember there being a Spoon 4-1 header for our application. The old 4-2-1 was indeed a 2 piece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">thats what i thought
so is the a one piece 4-2-1 2.5" header then?</TD></TR></TABLE>
Yes the Spoon 4-2-1 is 2.50 OD or IIRC almost exactly 2.375 ID.
But keep in mind that yes if you are lowered or planning on lowering that the Spoon has limited clearance.
http://www.ipsracing.com/manuf....html
there is a one piece 4-2-1, 2.5" and a two piece 4-2-1, 2.5". i highly doubt spoon would have created an aftermarket performance product offering a 2.25". especially with the 98+ JDM ITRs having a 2.5" collector size.
I have one that has a small scrape on the bottom (Not really a dent, just a scrape). I would be willing to trade for a header with better clearance (has to have 2.5" collector though, Type One perhaps?)
May be spending some cash on suspension this summer, so extra header clearance would be great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">I thought it was 60 millimeters.... ? = 2.36 in
Japanese products are all metric</TD></TR></TABLE>
It may be 60 mm ID, but OD is ~63.5 mm.
Hanging low?? Worried?? Get a skid plate!
http://estores.merchantpartner...id=90
Fastline Performance skid plates are the simple solution to saving your $400+ header from dents and scrapes, retaining its performance and resale value. The Fastline Performance Skidplate is the only solution to saving your JDM ITR 4-1 header. Get some peace of mind with an FLP Skidplate!
The Skidplate is made of 1/4" thick aircraft grade aluminum. The Skidplate weights just under 4 lb.. The most critical part of the header, the low hanging primany pipes at the front of the header, are protected from the daily abuse of steep driveways and speed bumps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">opt for a better ground clearance header......</TD></TR></TABLE>
like this?
like this?
Spoon does/did have a 4-1 header with a 2.5" collector (see pictures below). This may have only been intended for the B16, B18B and B18C and not the B18C5 (ITR). The 4-1 is nearly identical to the JDM ITR 4-1 header.
A little more info here --> http://hondawerx.com/Spoon/exhaust.htm
This picture shows the difference between the 4-1 and 4-2-1.
