quick ecu ?
Old Jan 31, 2006 | 06:20 PM
blackie's Avatar
Default quick ecu(chicago) ?
i live in il. i herd the emmisions testing here are kinda strict but nothing like ca. i have a 99 civic ex coupe along with a 99 usdm gsr swap. the wiring harness is also the same from the 99 ex. the 99 ex is obd2b. i am running a 99 si ecu and need a 99 usdm gsr one. i was wondering if since the 99 gsr ecu is obd2a, will i be able to pass? not including the other problems that i might have..just the ecu and year or car/motor part. let me know. thanks
Modified by blackie at 7:41 PM 1/31/2006
Old Jan 31, 2006 | 06:40 PM
2000EM1's Avatar
Default Re: quick ecu(chicago) ? (blackie)
A 99 GSR ecu is obd2b, I don't see why you wouldn't pass.
Old Jan 31, 2006 | 06:41 PM
blackie's Avatar
its obd2b? hrmm.. does the 99 ecu have the immobilizer or is that the 00-01?
Old Jan 31, 2006 | 07:58 PM
blackie's Avatar
how are you doing?
Old Jan 31, 2006 | 07:59 PM
blackie's Avatar
good
Old Feb 1, 2006 | 06:39 PM
blackie's Avatar
wednesday
Old Feb 1, 2006 | 07:18 PM
2000EM1's Avatar
Default Re: (blackie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackie &raquo;</TD></TR><TR><TD CLASS="quote">its obd2b? hrmm.. does the 99 ecu have the immobilizer or is that the 00-01?</TD></TR></TABLE>
I have no idea... but a bump for you.
Old Feb 2, 2006 | 08:11 PM
blackie's Avatar
tnx. bump for myself
Old Feb 5, 2006 | 11:24 AM
blackie's Avatar
bump
Old Feb 5, 2006 | 05:47 PM
mik101's Avatar
Will they fail you just because the ECU doesnt match the engine? If not I dont see what the problem is. Do the emissions test with the SI ecu (which is running lean for that motor and not controlling the IAB just FYI) then grab an OBD1 P72for the GSR and OBD2B to OBD1 conversion harness and run that the rest of the year (and in the process you'll gain alot more tuning capabilities if you wish to use them).
You could also use a P28 if you wanted to add the circuitry to control the IAB and chip it.
Or you could change the intake manifold if you dont want to use the IABs at all and just run a chipped P28 with the conversion harness.
Ofcourse you could also get an OBD2A GSR ecu and use the OBD2B to OBD2A harness.
The possibilities are endless.
What specifically do you want from it? Give us some more details and we can help you find a solution that will suit you best.
As far as I know all OBD2B GSR ecus have the immobilizer but dont quote me on that one.
Old Feb 5, 2006 | 05:51 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
Default Re: quick ecu(chicago) ? (mik101)
look at the name probalbly stol that car ..................theives
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mik101 &raquo;</TD></TR><TR><TD CLASS="quote">Will they fail you just because the ECU doesnt match the engine? If not I dont see what the problem is. Do the emissions test with the SI ecu (which is running lean for that motor and not controlling the IAB just FYI) then grab an OBD1 P72for the GSR and OBD2B to OBD1 conversion harness and run that the rest of the year (and in the process you'll gain alot more tuning capabilities if you wish to use them).
As far as I know all OBD2B GSR ecus have the immobilizer but dont quote me on that one.</TD></TR></TABLE>
Actually, I was told that the immobilizer was a 2000 model year addition,and that the 99 GSR ecu/ did not have it. Anyone know for sure?
Old Feb 5, 2006 | 06:27 PM
Syndacate's Avatar
Default Re: quick ecu(chicago) ? (96accordlxf22b2)
96accordlxf22b2
Offline
84 posts [100%]
murrieta ca
10-2-2005
« Re: quick ecu(chicago) ? (mik101) « » 9:51 PM 2/5/2006 Reply Edit
buy my stuff
http://hondamarketplace.com/ze...id=59
Now that's just racist...
Old Feb 5, 2006 | 06:52 PM
blackie's Avatar
wow thumbs down to 96accordlxf22b2 for the pointless comment...newayyys, i just want to be able to pass emissions, and not run the si ecu anymore. for one thing, i kno here in il we dont check for the year of the motor. i think i gotta stay obd2? for when i go in for testing. dont the older model gsr's have the fuel tank pressure sensor? which will throw a code? and i kno the 00+ gsrs have the immobilizer. i just need the proper ecu at the moment. i dont need anything to tune with and mess around with.
Old Feb 5, 2006 | 07:40 PM
ok srry im racist but some one like him stole my car and im pissed
Old Feb 5, 2006 | 08:25 PM
blackie's Avatar
hope you find it. my name refers to the fcolor of my car
Old Feb 6, 2006 | 04:58 PM
ok it better be lmao jk dude im not racist its just the way they act........................ok ok im joking im really not racist seriously im not.......................................and i did find it ty very much
Old Feb 6, 2006 | 06:21 PM
blackie's Avatar
is it true that the civic ex's come with the fuel tank pressure sensor already?
Old Feb 7, 2006 | 08:12 PM
blackie's Avatar
will i have any problems with the iab's when i run the gsr ecu? no right?
Old Feb 7, 2006 | 08:50 PM
y dont ya just steal a fuel regulator jk if they do have a fuel tank pressure sensor i have one yayyyyyyyyyyyyy lmao im no help but heres a free bump
Old Feb 8, 2006 | 08:15 AM
blackie's Avatar
bump
Old Feb 8, 2006 | 08:16 AM
SVOboy's Avatar
GSR ecu has iabs, so yeah.
Old Feb 8, 2006 | 07:25 PM
blackie's Avatar
nice thanks. i hpoe i dont run into any issues with the obd2b to obd2a harness wired up to a usdm 96-99 gsr ecu
Nameless Warrior
Apr 6, 2007 08:17 PM
swoyEKr.
Apr 13, 2006 04:56 PM
blackie
Jul 25, 2005 05:53 AM
AllMoToRB18c
Dec 9, 2003 07:45 AM
GsR HtCh
Feb 26, 2003 08:39 AM
