JUN 2 inatke cam/Skunk 2 stage 1...will it work
I may be running a JUN 2 intake cam, the exhasut cam however would be a Skunk 2 stage 1.
will I run in to any problems what so ever. here are the Spec's that I have got from both cams
JUN 2 exhasut = 10.9 mm, duration - 265.3 @ 1mm
Skunk @ = 10.9,,, duration 245@1mm
now is there going to be a big differance in HP or torque?? if so what should I expect
Do you already have the skunk2 stage 1 exhaust cam? If not then you should look into the stage 2 exhaust cam. I'm not too sure how HP will be affected. I'm guessing that you will make less peak power than a set of skunk2 stage 1's, but with more mid range just like how the jun2/itr combo works.
go turbo.......that way when your sick of it in a month you can sell it to me at a rediculously cheap price
an2ny888
May 21, 2005 08:58 PM
Green_Goblin
Oct 23, 2004 06:48 PM
