Clutch, throwout bearing, or tranny problem?
Old Jan 31, 2006 | 04:54 PM
Dignan's Avatar
Default Clutch, throwout bearing, or tranny problem?
I replaced my motor, installed a new clutch/TO Bearing/PP/FW. I swear I put it all in exactly as it came out.
Today (as I'm finishing all the little details), I decided to check if the motor turns when I spin the wheels with the car in gear. They don't. I can see the flywheel through the starter hole and it's not turning either.
So I'm afraid I messed up the throwout bearing replacement.
Could it be anything else? Axles are definitely in the tranny, and they both turn (opposite directions) when I manually turn them. Clutch feels like it's working (and I've adjusted the cable, tried both looser + tighter). I feel it engage, and the normal slack at the top of the pedal. Tranny feels like it pops into gear. All linkage hooked up.
I haven't re-filled the tranny yet.. could that be it?
Thanks in advance.
Old Jan 31, 2006 | 05:09 PM
jlicrx's Avatar
Default Re: Clutch, throwout bearing, or tranny problem? (Dignan)
unless you have LSD transmission, you can't turn the engine over by spinning the wheels unless you can spin both of them in the same direction at the same time - this is due to the differential action in the transmission - start it up and put it in gear and you should have at least one wheel turning
Old Jan 31, 2006 | 05:25 PM
Dignan's Avatar
Default Re: Clutch, throwout bearing, or tranny problem? (jlicrx)
1- Word.
2- Duh..
Thanks. I'm a retard.
typeWX
Jul 17, 2009 11:04 AM
teler86
Jan 24, 2006 06:30 PM
bambbrose
Dec 12, 2004 10:17 PM
90LSpimpin
11
Sep 19, 2004 10:13 AM
90LSpimpin
Sep 19, 2004 12:58 AM
