h22 powersteering bracket doesn't fit F22
I have a 94 lude that had an h22, i pulled the motor to begin working on it and put in a F22A1 to get by untill the build is done. what should be the power steering bracket looks more like an alternator bracket. now i tried the power steering bracket from the h22 and it doesn't come close to bolting up to the head. Anybody know what the difference is? Was the alternator on top in the accords and power steering in the middle? What bracket is the right one?
It's in the same position, & uses the same pump. It just uses a different bracket that bolts up differently to the F22 SOHC head. If you want power steering you'll need to get an F22 PS bracket.
i can check my shed and see if i have my old bracket from the h23... i cut it to fit the h22, so i know it fits but i dont know if you can do the same with the f22 one.
F22's have different PS brackets than H23 or H22's. You're gonna have to get a PS bracket specifically for an F22. If I was at home, I would have given you one free, but check the junkyards or somethin, you can get it off an accord for like $5.
