Engine wont start. not good
Old Jan 31, 2006 | 03:14 PM
TecHMec's Avatar
Default Engine wont start. not good
ok i was driving normal and was about 4000 rpms and all of a sudden it sound like straight headers. it got super loud. so it worried me very bad. i was lucky and was by my friends auto mechanic shop and stoped there. i then turned the car off....... big mistake. i went to go start it back and leave cuz he wasn't there. it didnt start. the starter seams to turn over but sounds like a muffled machine gun. then it tries to grab the flywheel. when it did, it sounds like the battery was dead... now it wont even crank the starter. now nothing happens. im super lost and need help. any help greatly appreciated. thanks
p.s i got the oil changed 20 mins previous to this happening. the motor does turn
over.
Old Jan 31, 2006 | 04:10 PM
P_Adams's Avatar
Default Re: Engine wont start. not good (TecHMec)
Any tell-take oil puddles under the engine?? Any oil in the crankcase??
Until you tell us otherwise, it could be anything; and any answers at this point are guesses.
I'm going to assume it's an Oil Change that's gone terribly wrong. Hopefully, you weren't victimized by a bad Oil Filter Base Gasket. If that failed, you lost your oil, and thus your oil pressure within about a minute. Hopefully the Engine didn't try to imitate a Grenade
I was originally going to mention blowing a Spark Plug from the Head, or the Front Exhaust Pipe failing; but that doesn't answer why the starter issues. Engine internal problems do.
P
Old Jan 31, 2006 | 06:00 PM
TecHMec's Avatar
Default Re: Engine wont start. not good (P_Adams)
hmmm.i dont know. one of the guys from cb7tuner mensioned the same thing about the spark plug and down pipe. ill have to check it out. hopefully the oil theory is not the issue. thanks again
miatech
Feb 9, 2012 04:26 PM
antig24
Sep 3, 2010 12:13 PM
ITR0842
Mar 13, 2010 02:56 AM
iperez
Sep 8, 2007 05:18 PM
krypto2006
Aug 8, 2006 11:05 AM
