Starting problem
Old Jan 31, 2006 | 11:25 AM
Fabritory's Avatar
Default Starting problem
I just bought an 98 dx hatch and im having trouble staring it .....the engine has a new battery it gets spark the fuel pump werks the relays and everything are in good shape it just turns over slowthe starter make no grinding or wierd noises and seems to be in good shape also could this be an internal engine problem
Old Jan 31, 2006 | 02:20 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: Starting problem (SuperStario)
Try checking your grounds and make sure it's tight... I had the same problem before..
Old Jan 31, 2006 | 02:26 PM
stitch420's Avatar
Default Re: Starting problem (CiViC_I2aCeI2)
is ur check oil light coming on when it does this????cause im having the same problem and i know its not my oil doing it....
Old Jan 31, 2006 | 03:02 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: Starting problem (stitch420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stitch420 &raquo;</TD></TR><TR><TD CLASS="quote">is ur check oil light coming on when it does this????cause im having the same problem and i know its not my oil doing it....</TD></TR></TABLE>
No my oil light wasn't on.....
preludeguy_92
Jun 5, 2005 07:57 PM
temp
11
Jul 8, 2004 11:47 PM
hondaracing1
Mar 27, 2004 05:38 PM
hondaracing1
Mar 27, 2004 01:46 PM
