Best Ecu for a B16a2 motor
Old Jan 31, 2006 | 09:45 AM
Rionmann's Avatar
Default Best Ecu for a B16a2 motor
I have been searching on this website and have not found all the info I was looking for. So, I wanted to know what you guys thought was the best ecu for a B16a2 motor.
Old Jan 31, 2006 | 09:50 AM
gunnis's Avatar
Default Re: Best Ecu for a B16a2 motor (Rionmann)
The stock one?
You'll need to provide a little more info.
Stock motor?
Did the motor come in this car originially?
Are you doing a swap?
Obd conversions needed?
help us, help you.
Old Jan 31, 2006 | 09:54 AM
Rionmann's Avatar
Default Re: Best Ecu for a B16a2 motor (gunnis)
Well the B16a2 is going into my Eg civic. The motor is stock with no modifications to it, but I will look at doing that in the summer, but for now I looking for an ECU to run the motor. If you need more info I will put it in...
Old Jan 31, 2006 | 10:04 AM
Turboed00EM1's Avatar
I say a P28 OBDIIB-OBDI conversion..... You can get Erick's Racing to chip and your set with a 20HP gain....
eg2sol's Avatar
I would say p-30 or you could get a chipped p28 for about the same price.
Old Jan 31, 2006 | 10:12 AM
Rionmann's Avatar
Default Re: Best Ecu for a B16a2 motor (eg2sol)
So, I could a P28 or P30, but the P28 has to be chipped for it work...
Old Jan 31, 2006 | 10:20 AM
eg2sol's Avatar
correct
Old Jan 31, 2006 | 10:24 AM
Rionmann's Avatar
Thanks
Old Jan 31, 2006 | 04:05 PM
SVOboy's Avatar
Default Re: Best Ecu for a B16a2 motor (Turboed00EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboed00EM1 &raquo;</TD></TR><TR><TD CLASS="quote">I say a P28 OBDIIB-OBDI conversion..... You can get Erick's Racing to chip and your set with a 20HP gain....</TD></TR></TABLE>
Got some dyno sheets for that 20hp on a stock b16a2?
Just chip a p28, it'll come in handy down the road.
Old Jan 31, 2006 | 04:10 PM
743power's Avatar
Default Re: Best Ecu for a B16a2 motor (SVOboy)
chipped p28 or p06
jdm p30 with 110mph speed limiter
UBER rare usdm p30
Old Jan 31, 2006 | 05:05 PM
hapexamendios 2.0's Avatar
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnis &raquo;</TD></TR><TR><TD CLASS="quote">The stock one?
Stock motor?
help us, help you.</TD></TR></TABLE>
Old Jan 31, 2006 | 05:06 PM
hondapwr's Avatar
Why does the P28 need to get chipped to work?
And why does he need the OBD conversion? Where is the B16 from? JDM Civic, USDM Del Sol, or USDM 99-00 Si?
Old Jan 31, 2006 | 05:21 PM
743power's Avatar
Default Re: Best Ecu for a B16a2 motor (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr &raquo;</TD></TR><TR><TD CLASS="quote">Why does the P28 need to get chipped to work?
And why does he need the OBD conversion? Where is the B16 from? JDM Civic, USDM Del Sol, or USDM 99-00 Si?</TD></TR></TABLE>
b16a2 = usdm 99-00 civic si
I have heard people say it can also be from a del sol vtec, but I have never found proof of it.
unchipped p28 won't run the twin cam properly. Wrong maps. It will run the car and you can drive with it, but it is not smart.
Old Jan 31, 2006 | 06:36 PM
hondapwr's Avatar
Default Re: Best Ecu for a B16a2 motor (743power)
If he hasn't already bought it, I'd suggest getting a JDM B16. That way it's already OBDI and he can run an OBDI P72 ECU or other chipped ECU. I'd imagine a true USDM 99-00 Si B16 would cost more..
Old Jan 31, 2006 | 06:39 PM
2000EM1's Avatar
I'd personally run an obd1 chipped P30. knock sensor is already wired in, but a chipped P28 would work.
Old Jan 31, 2006 | 06:44 PM
dohcVTECeg2's Avatar
you can use the OBD-I P30. that one is the correct ECU for your motor. but i would recommend buying a P28 and getting that chipped. once you get that run open header and tell me what you think...mmmmmmmmmBAHHHHHHHH!!!!!!!!
Old Jan 31, 2006 | 07:01 PM
94eg2sol's Avatar
Default Re: Best Ecu for a B16a2 motor (dohcVTECeg2)
would a p30 be found in a single vtec del sol .. if not what type of ecu does del sol carry (single 1.6l vtec)
Old Jan 31, 2006 | 07:02 PM
SVOboy's Avatar
Default Re: Best Ecu for a B16a2 motor (94eg2sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg2sol &raquo;</TD></TR><TR><TD CLASS="quote">would a p30 be found in a single vtec del sol .. if not what type of ecu does del sol carry (single 1.6l vtec)</TD></TR></TABLE>
p28 = d16z6 = 1.6 vtec sohc
Old Feb 1, 2006 | 05:24 AM
hondapwr's Avatar
A very limited number of Del Sol's came with a B16. (Del Sol VTEC)
That is the only USDM P30 ECU I can think of..
Old Feb 1, 2006 | 06:48 AM
dso's Avatar
dso
yes, but the b16a2 is also from the 92-95 SiR eg6 in japan, and i think a VtiR civic EK as well.
Old Feb 1, 2006 | 09:17 AM
hondapwr's Avatar
Default Re: Best Ecu for a B16a2 motor (dso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dso &raquo;</TD></TR><TR><TD CLASS="quote">yes, but the b16a2 is also from the 92-95 SiR eg6 in japan, and i think a VtiR civic EK as well. </TD></TR></TABLE>
Are there any issues with using a JDM ECU on your USDM chassis?
Old Feb 1, 2006 | 09:45 AM
Boosted2000B16's Avatar
The b16a2 came in the 99-00 civic si, the one that you were talking about in the del sol I believe is the b16a3. I would do a obd 2 to 1 converion and run a p28 chipped that way in the future if u decide to turbo the car then your ECU is already tuner freindly!
Old Feb 1, 2006 | 07:15 PM
dso's Avatar
dso
i don't quite understand your question cause the ecu doesn't have to do with the chassis of a car.
Old Feb 1, 2006 | 07:17 PM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dso &raquo;</TD></TR><TR><TD CLASS="quote">i don't quite understand your question cause the ecu doesn't have to do with the chassis of a car.</TD></TR></TABLE>
You're right, it doesn't have to do with the chassis, but the OBD level would have to do with the year of the model it was in. A P2T is obdIIb, because it was in a car that was manufacured in the years of 99-00, which were obdIIb.
Old Feb 1, 2006 | 07:24 PM
djpeetur's Avatar
[quote] don't quite understand your question cause the ecu doesn't have to do with the chassis of a car. [quote]
lol
