can you mig a manifold
Old Jan 31, 2006 | 06:30 AM
ilsimsli's Avatar
Default can you mig a manifold
ive seen this question before but i searched and couldnt find an answer can you mig a manifold how much of a difference would there be between tiging and miging. would you be able to mig a good quality manifold or no. can anyone show the differnces between a migd and tigd manifold
thanks
Old Jan 31, 2006 | 06:33 AM
8mpg's Avatar
Default Re: can you mig a manifold (ilsimsli)
you CAN mig it but I really wouldnt.... The welds wont come out nearly as clean, tight spaces will be very hard to weld and its harder to weld stuff like stainless or aluminium
Old Jan 31, 2006 | 06:46 AM
beepy's Avatar
Default Re: can you mig a manifold (8mpg)
IMHO... If you have a decent MIG welder the manifold will be just as sound. Hell, I have even made suspension parts with MIG. Structurally it is fine. However you will never be able to get that sweet rainbow-colored stacked coin look with MIG.
Old Jan 31, 2006 | 06:57 AM
ilsimsli's Avatar
Default Re: can you mig a manifold (beepy)
beepy what kind of metal are u using to make manifolds? and what size?
Old Jan 31, 2006 | 07:10 AM
PolyPill's Avatar
I got a friend that MIGs his Nissan 300zx headers all the time, looks like total *** but it works, 636whp He uses mild steel. Just make sure you do a leak down test....although you should do that with TIG too.
Old Jan 31, 2006 | 07:18 AM
beepy's Avatar
Default Re: can you mig a manifold (PolyPill)
I use sch10 stainless and various mild steels. Beveled edges, 2 passes, with 0.028" wire. 75/25 mix gas. I get a little higher crown with stainless, but after some practice I think my welds are looking decent.
Of course, my next leap may be to buy a TIG.
Old Jan 31, 2006 | 08:41 AM
jaydmcrx's Avatar
pulsed mig, no spatter
Old Feb 1, 2006 | 04:45 AM
S2KP's Avatar
Default Re: can you mig a manifold (jaydmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">pulsed mig, no spatter </TD></TR></TABLE>
I still prefer tig tho
Old Feb 1, 2006 | 10:57 AM
jaydmcrx's Avatar
Default Re: can you mig a manifold (PANG)
well duh!
Old Feb 1, 2006 | 11:12 AM
stealthmode62's Avatar
Tig welds are for fancy asses.
Old Feb 1, 2006 | 02:24 PM
ManBearPig4silly's Avatar
Default Re: can you mig a manifold (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> Tig welds are for fancy asses. </TD></TR></TABLE>
Did you just call me a fancy ***?
Old Feb 1, 2006 | 04:14 PM
paulzy's Avatar
Default Re: can you mig a manifold (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">Did you just call me a fancy ***? </TD></TR></TABLE>
brokeback mountain?
lolz, but MIG is fine. If you don't care about the bling bling look, the MIG will be perfectly fine.
Old Feb 1, 2006 | 04:29 PM
Default Re: can you mig a manifold (paul vang)
Ok, I'm outta here. Someone said brokeback mountain. lol
Old Feb 13, 2006 | 09:58 PM
Touge Tuning's Avatar
can you use a 110V MIG (with gas shielding) to weld manifolds is the question id like to know
Old Feb 13, 2006 | 10:25 PM
jaydmcrx's Avatar
Default Re: (Stealth1)
I would not reccomend it. But if you went to home made turbo they would praise you like a god. Wich would be sweet. Cuz home made turbo rules
Old Feb 14, 2006 | 05:18 AM
90DALS's Avatar
Default Re: (jaydmcrx)
tig is better, but ive seen a mig manifold personally handle 280+whp on a d-series and last a few years and still is on the car today.
Old Feb 14, 2006 | 07:51 AM
nblkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">home made turbo rules </TD></TR></TABLE>
my thoughts exactly
Old Feb 14, 2006 | 03:02 PM
model x's Avatar
Default Re: (nblkid)
I used an old 90amp 110v miller to do mine. Cranked up the voltage and the manifold has been holding(no braces) my holset turbo for a year so far and makes 270whp.
Old Feb 15, 2006 | 08:05 PM
Bailhatch's Avatar
Default Re: (model x)
I have made a lot of sch 40 mild steel manifolds with my lincoln110 MIG. They come out pretty nice and none have ever broken that Im aware of.
Old Mar 9, 2008 | 08:54 AM
93supercoupe's Avatar
Default Re: (Bailhatch)
what kind of machines are u guys using to do this?
Old Mar 9, 2008 | 10:35 AM
boostedgsr1234's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I use sch10 stainless and various mild steels. Beveled edges, 2 passes, with 0.028" wire. 75/25 mix gas. I get a little higher crown with stainless, but after some practice I think my welds are looking decent.
Of course, my next leap may be to buy a TIG.</TD></TR></TABLE>
when you say 2 passes, do you mean you go over the seams with filler then braze over it?
Old Mar 9, 2008 | 11:50 AM
G2turbo_terror's Avatar
Default Re: can you mig a manifold (boostedgsr1234)
I've miged a sch. 40 MS ram horn, turned out fine. The hardest part was using a 110V welder w/a 20% duty cycle ...a lot of down time.
Old Mar 9, 2008 | 12:52 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have made a lot of sch 40 mild steel manifolds with my lincoln110 MIG. They come out pretty nice and none have ever broken that Im aware of.</TD></TR></TABLE>
Cause you changed your legal name like 18 times... just kidding. I remember your work with the mig gun, good stuff.
Yes you can mig a manifold, will you get laid with putting down a mig weld.... aww probably not, girls love the color.
Then again ManBearPig4silly is pretty desperate these days
Old Mar 9, 2008 | 02:11 PM
Bailhatch's Avatar
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">
Then again ManBearPig4silly is pretty desperate these days </TD></TR></TABLE>
Haha ya
MIG is fine, there's a thread on this every month...this is just an old one.
Old Mar 10, 2008 | 01:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: can you mig a manifold (G2turbo_terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2turbo_terror &raquo;</TD></TR><TR><TD CLASS="quote">I've miged a sch. 40 MS ram horn, turned out fine. The hardest part was using a 110V welder w/a 20% duty cycle ...a lot of down time.</TD></TR></TABLE>
i was gonnna chime in about duty......
Blove1991
Dec 19, 2011 06:50 PM
h22 civic
Mar 14, 2008 12:13 PM
Vtec92Civic
Jan 24, 2004 02:47 AM
Infinity_Racer
Jul 11, 2003 11:58 AM
