best for removing graphic residue?
get a towel, put pretty hot water on it, but it over the sticky for a minute, then slowly peel off sticker while sliding towel. it works. then if you wanna use goo gone after you can, but usualyl the towel finished the job just fine
hairdryer/heat gun for a min, and use goo gone to finish it up.
make sure you use some 100% cotton towel so you wouldnt make fine scratchs on the surface.
rinse and clean the goo gone up because they do discolor many finishes if you leave them on overnight(mainly on syn. rubber/plastic, read: interior of your honda)
wax the area afterward
DVS2000
Jun 19, 2003 11:17 PM
LuderCriS
Aug 27, 2002 07:29 PM
