Removing stock wing with led brake lamp, how many holes will be left??
I've got a 92' Si and its got the stock wing with the led brake light on it. I was wondering what I'd be left with if I took the wing off anf if there would be a gaping hole for the wire harness the run through for the brake lamp, also i need something to plug the holes with (rubber plugs and rtv?). Should I go wingless or save my self the trouble?
save yourself the trouble. there wil be 5 holes, if its anything like the 5th gen preludes and it probably is. 2 bolts on eithet side of the trunk, and 1 hole for the wires. you could plug them with rubber inserts, but that would look ghetto. and if you choose to seal them up with metal and bondo you will have to repaint the trunk. like i said, save yourself the trouble.
Why are you taking the spoiler off? I think I missed that part.........
but anyway - here's what you will see.........
4 holes
the wiring is on the very left when facing the trunk. You'll see a black and a green wire - green is power, black is ground.
I really don't know what you would plug it up with though......
4 holes
Eg_TypeR
Paint and Body
Feb 25, 2008 05:22 PM
comptechgsr
Jul 15, 2001 08:52 PM
