Need Help, EF idling at 2 grand
Old Jan 30, 2006 | 06:47 PM
Bajerek's Avatar
Default Need Help, EF idling at 2 grand
I've got a
89 d16a6 1.6 single cam non v-tec balanced crank and rods stock pistons and rings,shaved head,5 angle valve job,ported intake man,tb bullfrog butterfly,bullfrog stage 2 cam si ecu chipped rev limit at 7000rpm hard AEM short ram intake 1st gen b16 injectors b and m fuel pressure regulator 91 si tranny
But when I turn on the car it idles at 2'000rpm, did anybody had a problem like this....
and I get a code saying I don't have enoiugh grounds, althou I checked ever one of them and they all seem intact.
Can you guys help a brotha out..... any ideas what to do ???
Old Jan 30, 2006 | 07:23 PM
Bajerek's Avatar
Default Re: Need Help, EF idling at 2 grand (Bajerek)
anybody ???
any ideas , come on ,there has to be somebody that knows
redasphalt's Avatar
check for vacuum leak, eacv, fitv
Old Jan 30, 2006 | 07:32 PM
kulangot's Avatar
Default Re: Need Help, EF idling at 2 grand (redasphalt)
mine ides at 2 grand..its cold start...well mine is..
Old Jan 30, 2006 | 10:50 PM
M15's Avatar
M15
Default Re: Need Help, EF idling at 2 grand (kulangot)
Mine idles at 2 grand also, I just got used to it.
Old Jan 30, 2006 | 11:00 PM
.Manny.'s Avatar
Touching My Member
have you messed with the idle screw on the intake manifold, my dohc zc was idling high too and i brought it down to 1000 when warm and about 1500 when cold
Old Jan 30, 2006 | 11:15 PM
Burlyirishdude's Avatar
Default Re: (90_EF_Si)
Check the IAVC....and the TB....Search under "b16a+idle+IAVC" You should see the problem with the Coolant sensor in the thingy under the TB....it should apply to your 1.6. Take it off...Disconnect the 3 coolant lines.....Open the thing up and Screw iwth your hand the white plastic thing inside. All the way down. It should bring your idle down and then adjust the idle screw...that's if it's not epoxied up. Good luck dude hope it works.
Nothing sounds better then a Car that sounds stock at idle and Sounds even better half way down the street when he hears your vtec crossover... SNIPER STYLE.
Old Jan 31, 2006 | 11:55 AM
Bajerek's Avatar
Default Re: (Burlyirishdude)
Where is the idling screw ??? I actually didn't know there is one, I thought those motors didn't have one.... I just bought the car , and I thought of swapping a B18B, but if I can make it run properlly, I'll just turbo it.
So where can I find it ???
anybody got a picture ???
Old Jan 31, 2006 | 11:58 AM
Bajerek's Avatar
Default Re: (Bajerek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bajerek &raquo;</TD></TR><TR><TD CLASS="quote">Check the IAVC....and the TB....Search under "b16a+idle+IAVC" You should see the problem with the Coolant sensor in the thingy under the TB....it should apply to your 1.6. Take it off...Disconnect the 3 coolant lines.....Open the thing up and Screw iwth your hand the white plastic thing inside. All the way down. It should bring your idle down and then adjust the idle screw...that's if it's not epoxied up. Good luck dude hope it works.
Nothing sounds better then a Car that sounds stock at idle and Sounds even better half way down the street when he hears your vtec crossover... SNIPER STYLE. </TD></TR></TABLE>
Don't know what you said, can you explain, sorry, don't know these shortcuts....
I'm sorry for being such a pest.
Old Jan 31, 2006 | 05:48 PM
Bajerek's Avatar
I fixed it ... it wasn't the idle screw, it was the tensioner on the throtlle body.
The guy who did the swap, never installed it , so I installed one from a 1994 civic, works like a charm.
Old Jan 31, 2006 | 06:46 PM
congrats....
The iavc is the little bottle looking thing undeneath the throttle body and it controls the idle air vaccum as the car is indle. The coolant actually controls the throttle body and Gives the car that funky idle b/c it still thinks it's cold and whatnot. On the inside is a plastic screw that Sinks down when twisted. it's like a manual override ofthe Iavc by keeping the screw looked at it's Lowest setting causing the idle to come down...letting you adjust just the idle screw.
But F_ck it you got it with the tensionor....Good sh_t
Old Jan 31, 2006 | 07:20 PM
Bajerek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">congrats....
But F_ck it you got it with the tensionor....Good sh_t </TD></TR></TABLE>
Well what happend was I bought the car from the guy today, he put over $2'000 ( canadian) in the motor. But he didn't even adjust it, never tunned it... So now that I got it, I will take ever possible free hour to work on it to perfect what I have once gave up on...
( I use to have an EF, dropped a DOHC ZC motor in it , and sold it... its time to redeem myself )
Thank you for the help, and expect me to be here , more often then I was.... mostlly for the Appearance section, but not anymore.I'll post some pictures tomorrow
1991si
Feb 25, 2013 01:25 PM
90crxdriver
Jun 24, 2007 03:32 AM
TurboJdmEF9
Apr 14, 2006 07:44 PM
slowcrxsi
Mar 28, 2006 12:37 PM
s2000 mf
Oct 26, 2004 01:06 PM
