What engine swap to do?
Old Jan 30, 2006 | 05:56 PM
farmboy777's Avatar
Default What engine swap to do?
Hey guys,
have been looking at all the diferent threads on different engine's, mini-me's etc... so i need some advice on what to work towards.
for starters i've got a 91 SI hatchback curenntly with a SOHC ZC (with 60,000 km on it, or so i've been told haha)
its peppy but i want more power while keeping it reliable this is a daily driver.
so what would be the best idea,
option one: DOHC ZC swap
option two: mini/me swap with z6 head
option three: build current motor, can i put DOHC ZC pistions in my SOHC ZC? or are their better pistons to raise compression?
give me your thougths idea's etc. i will not be getting into forced induction or NOS it will stay N/A and i wanna keep it on the cheap getting the most bang for thr buck
thanx for any ideas suggestions guys
Old Jan 30, 2006 | 06:03 PM
Pee Wee's Avatar
Default Re: What engine swap to do? (farmboy777)
cheap + N/A = not possible
Old Jan 30, 2006 | 06:12 PM
Mach69's Avatar
If you want to keep it D-series with N/A, I would do the mini-me. Put some pistons that bump the compression to 12:1. Y8 intake manifold. Upgrade the valvetrain, and balance the bottom end so I could rev to 8k.
Old Jan 30, 2006 | 06:40 PM
Pee Wee's Avatar
Default Re: What engine swap to do? (Mach69)
but he said he didnt want to spend alot
Old Jan 31, 2006 | 08:18 AM
farmboy777's Avatar
if i did the mini me and swapped pistons would i see a difference over if i had just done the mini me? how high compression should i look to end up with to run on 91 gas, because i could shave the head before i put it on to right?
tecster9
May 12, 2008 12:34 PM
9db85
Dec 21, 2006 05:51 PM
xxmikexx206
Dec 30, 2005 09:22 PM
brg2nr
Feb 19, 2005 12:45 PM
chron1k
Oct 19, 2002 11:31 AM
