FS: Stock parts CRX, EG-Civic SI, LS Integra parts
Old Mar 24, 2002 | 10:45 AM
Elmdale's Avatar
Default FS: Stock parts CRX, EG-Civic SI, LS Integra parts
Make offer
Stock parts: 88-91 CRX and 92-95 Civic
1) 92 Civic Si stock oem intake
2) 92 Civic Si stock oem corners
3) 92 Civic Si stock oem radiator cap
4) 92 Civic Si stock oem oil cap
5) 92 Civic Si stock fuel pressure regulator
6) 92 Civic Si stock oem battery tie down
7) 92 Civic Si stock oem shifter
8) 92 Civic Si stock oem shift ****
9) 92 Civic Si stock oem e-brake handle
10) 92 Civic Si stock oem cigarette lighter
11) 92 Civic Si stock oem 14” steelies with hub caps
12) 92 Civic Si Single cam oem honda valve cover
13) 92-95 Civic Si/EX clock
14) 92-95 Civic-2 Front Stock Springs
15) 92 Civic Si Hatch oem stock taillights
22) 92 Civic SI stock Cat-back exhaust system
23) 92 Ls complete head
24) 92 Ls starter
25) 92 Ls clutch with pressure plate
26) 92 Ls spark plug wires
27) 92 Ls Intake mainfold w/ throttle body
16) 88-91Crx e-brake console
17) 88-91Crx steering wheel plastic column cover
18) 88-91Crx door handle passenger (outer)
19) 88-91Crx back storage compartment boxes
20) 88-91Crx steering wheel
21) 90-91 Crx Si seats
Old Mar 24, 2002 | 10:58 AM
EF-9SiR's Avatar
Default Re: FS: Stock parts CRX, EG-Civic SI, LS Integra parts (Elmdale)
do you have the rear brakes off the crx?
Old Mar 24, 2002 | 11:03 AM
jdmhatch's Avatar
What color is the e-brake handle from the 92? Do you have the black shift boot also? Where are you located? Your willing to ship right. Thanx.
Elmdale
Mar 25, 2002 07:42 PM
Elmdale
Mar 21, 2002 01:03 PM
