how do i tell what kind of tube i have?
Old Jan 30, 2006 | 04:55 PM
boosted94cx's Avatar
* B A N N E D *
Default how do i tell what kind of tube i have?
i just picked up a 92 civic shell for $200.....
my friend had some welded in mild steel base plates in the front and on the shock towers...and had a main hoop, rear bars, and halo bent up for it as well
he said the bars were cro-moly..but i'm not sure how to tell. i set them outside last night..came back and they were flash rusted all over...does that mean they're steel? cause i hvae no clue.
they don't have any markings on them or anything either...
would the thickness determine the metal? or should i just post some pics?
Old Jan 30, 2006 | 05:34 PM
3s-gte sw20's Avatar
Default Re: how do i tell what kind of tube i have? (s13-t)
chromoly is steel and it probably rusts faster than mild steel
Old Jan 30, 2006 | 05:39 PM
* B A N N E D *
oh....didn't know that
so how do i tell for sure..before i go mig it in?
Old Jan 30, 2006 | 06:03 PM
david@didrace.com's Avatar
Default Re: (s13-t)
Only simple way I know of is to hope the labeling is still somewhere on the tube or ask the person that threw it in.
Old Jan 30, 2006 | 06:05 PM
* B A N N E D *
i don't trust the person i got it from
and as far as i've seen....no labeling
Old Jan 30, 2006 | 09:46 PM
tony1's Avatar
Default Re: (s13-t)
You can measure the thickness, if it's over .110" then it's probably mild steel.
Old Jan 30, 2006 | 11:03 PM
blueoval557's Avatar
Default Re: (tony1)
Yea, measuring thickness is probably your best bet. Anything over .095 or so is more than likely mild steel. If it is thinner, it is probably chrome-moly. Also...chrome-moly comes with a black coating on it...so if its a bright shiny type of looking metal, it is mild steel...unless for whatever reason someone stripped all the 4130 coating off of it???
Kyle
Old Jan 31, 2006 | 07:43 AM
* B A N N E D *
it does appear to hvae a coating.......
Old Jan 31, 2006 | 08:07 AM
beepy's Avatar
Default Re: (s13-t)
Chrome moly steel is very hard. If you strike it on a tangent with a hard stone it should spark. Mild steel won't do that.
Alternatively, try grinding on it. Chrome moly steel should send off sparks that burst into little spark clusters. High-carbon steel has a similar effect but tubing isn't made out of this material.
Old Jan 31, 2006 | 08:19 AM
* B A N N E D *
well...i'm going to gauge the thickness today..
if it's cro-moly...that's gonna suck, cause i don't have any use for it
urnotfast
Jun 27, 2009 08:44 AM
vtecb18c
16
Sep 5, 2008 01:45 PM
nate24740
Welding / Fabrication
May 27, 2008 04:21 AM
cua0
Jan 11, 2007 08:37 PM
TeamNextGenChris
12
Sep 14, 2006 12:11 PM
