headlight trouble
i just replaced my driver side headlight assembly and now the headlight doesn't work. It isn't the light because I tried to see if it worked on the passenger side and it work so it must be the thing powering the light on the driver side. How would I go about fixing this?
I dont get it, what exactly did you do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kgrules12 »</TD></TR><TR><TD CLASS="quote"> It isn't the light </TD></TR></TABLE>
You mean the bulb?
You mean the bulb?
its not the bulb, its the thing powering the bulb because when I stick the bulb into the passenger side it works but it doesn't work on the driver side
check fuses cause I believe there is one for each side, also did you try high beams? are they projector headlight? Lastly you can do a voltmeter and check continuity as a last resort to find the break in the circuit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTcivicHB »</TD></TR><TR><TD CLASS="quote">check fuses cause I believe there is one for each side, also did you try high beams? are they projector headlight? Lastly you can do a voltmeter and check continuity as a last resort to find the break in the circuit.</TD></TR></TABLE>
Close but you need to check for power and ground rather than continuity. Also do what was suggested and check fuses. Of course you know not to touch the bulbs with your bare skin.
Yeah, the fuse was blown and I just replaced it with a spare and it worked. The assembly is a honda assembly, the only reason I can figure why it would blow is because when I was replacing the old assembly the bulb in my old assembly went dead right after I took the assembly off so thats probably what did it, I got a new bulb and a new fuse and it works again, thanks for all the help
