225/50/16 on stock wheels
Old Jan 30, 2006 | 02:10 PM
thabends's Avatar
* B A N N E D *
Default 225/50/16 on stock wheels
ok ok. i know its been talked about. but never really cleared up. does anyone here see any major downsides to doing this. i mean, why do those wrx drivers like em so much on their stock 6.5" wheels? wouldnt they just give you more contact with the road and perform better? who's got answers...pros/cons. thanks
Old Jan 30, 2006 | 02:14 PM
6SPD_EK's Avatar
Default Re: 225/50/16 on stock wheels (thabends)
I didn't even think you could get 225's on a 6.5" wide 16" wheel
Old Jan 30, 2006 | 02:39 PM
MidNit's Avatar
Awesome, someone else who likes Aesop Rock too, heh.
Yeah, I'm with AdirondackR, I didn't know you could go that wide on only 6.5" rims... I've got 205/40zr17 on my 17x7.5" rims, but they're a bit small, I was thinking maybe 215 next time around... But seriously, 225 on 6.5" seems way off, not sure if there are any pros/cons of doing this.
Old Jan 30, 2006 | 03:29 PM
thabends's Avatar
* B A N N E D *
well i know for sure it can be done. after all, the rim width rating on most all 225/50/16 tires is 6-8". and many guys on ephatch have them and say they actually prefer it. and a hell of a lot of wrx say the same. but i cant find anyone that can clearly tell me why or why not i should do it.
Old Jan 30, 2006 | 03:41 PM
BarracksSi's Avatar
Default Re: (thabends)
I think 225's would be pushing it, but apparently it's not impossible. They'll fit inside the wheel wells, too.
I'd like to get 225's on my possible next set of rims, which would be 7" wide. Team Dynamics Pro Race 1 wheels in a 15" size, and they'd fit over my type-s brakes.
Old Jan 30, 2006 | 04:10 PM
honda93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabends &raquo;</TD></TR><TR><TD CLASS="quote">well i know for sure it can be done. after all, the rim width rating on most all 225/50/16 tires is 6-8". and many guys on ephatch have them and say they actually prefer it. and a hell of a lot of wrx say the same. but i cant find anyone that can clearly tell me why or why not i should do it.</TD></TR></TABLE>
I will be using that size tire on the same size wheel for stock class autocrossing with my new FG Coupe.
If you plan on autocrossing, fantastic. If not, fantastic.
Old Jan 30, 2006 | 04:30 PM
thabends's Avatar
* B A N N E D *
Default Re: (honda93)
which tire will you be using. im assuming the stronger the sidewall the better.
Old Jan 30, 2006 | 05:09 PM
96 SOHC VTEC's Avatar
Default Re: (BarracksSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">I think 225's would be pushing it, but apparently it's not impossible. They'll fit inside the wheel wells, too.
I'd like to get 225's on my possible next set of rims, which would be 7" wide. Team Dynamics Pro Race 1 wheels in a 15" size, and they'd fit over my type-s brakes. </TD></TR></TABLE>
I don't know about that chief. I tried to put my friend's 15" wheels over my Type-S brakes and they wouldn't fit. They fit on his ITR brake setup easily, but mine got stuck.
Old Jan 31, 2006 | 06:49 AM
SonicK20Z's Avatar
seconded. I had a 05 RSX-S and I had to use 16's for my track wheels. 15's wouldn't clear the front brakes.
Old Jan 31, 2006 | 08:00 AM
honda93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabends &raquo;</TD></TR><TR><TD CLASS="quote">which tire will you be using. im assuming the stronger the sidewall the better. </TD></TR></TABLE>
Kumho V710
225/50/16
$171 each from the Tire Rack
Add in $1000 custom Konis and an aggressive autocross alignment and go have fun.
Old Jan 31, 2006 | 10:44 AM
rawsx's Avatar
i vote for 215's
Old Jan 31, 2006 | 12:27 PM
thabends's Avatar
* B A N N E D *
Default Re: 225/50/16 on stock wheels (rawsx)
there's very little selection in 215/50/16
Old Jan 31, 2006 | 12:39 PM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabends &raquo;</TD></TR><TR><TD CLASS="quote">there's very little selection in 215/50/16</TD></TR></TABLE>
new azenis RT-615 come in 215/45/16....not sure if thet are out yet
those are the tires I am getting on my 16" te-37's
Old Jan 31, 2006 | 12:50 PM
BarracksSi's Avatar
Default Re: (96 SOHC VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 SOHC VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I don't know about that chief. I tried to put my friend's 15" wheels over my Type-S brakes and they wouldn't fit. They fit on his ITR brake setup easily, but mine got stuck. </TD></TR></TABLE>
Seriously? The Pro Race 1 wheels fit on his DC5R Brembos (barely, as I've seen in pics) but not on your OEM Type-S brakes?
Hmm.........
Old Jan 31, 2006 | 01:19 PM
BarracksSi's Avatar
Here are the pics k20tuRbo over at clubrsx posted of 15" Team Dynamics Pro Race 1 wheels on his Type-S with OEM brakes:
These are among the only 15" rims I've ever heard of that would fit on a Type-S.
Modified by BarracksSi at 3:07 PM 2/1/2006
Old Feb 1, 2006 | 12:01 PM
sdcivic549's Avatar
I've had as wide as 235's under my EM2, with a little fender rolling and only a little rub at full lock or full compression.
I'd not reccomend 225's on a 6.5" wheel unless you're using R-comps. Most any street tire won't have stiff enough sidewalls to keep the tires from rolling over and doing odd things cornering.
Old Feb 5, 2006 | 07:35 PM
Kidnkorner's Avatar
you would need a wider wheel to benefit from a wider tire. the shoulders would be round instead of square.
Old Feb 6, 2006 | 09:02 AM
Todd00's Avatar
I said I don't want a title!
Sure, you can mount a 225/50/16 street tire on the oem 6.5" wheel, but don't expect a crisp-handling car. Overall grip my be better, but transition feel is gonna suck.
A 225/50/16 R compound has a significantly stiffer sidewall than any street tire in the same size. Apples to Oranges.
I put 205/55/16 Azenis RT215's (found someone who still had a new set) on my oem rims and they work OK on the stock rim. I personally wouldn't go any wider with a tire on the OEM rim unless you are after the 'meaty' look.
Old Feb 6, 2006 | 09:11 AM
aznboysrfr's Avatar
it's not recommended to put a 225 on a 6.5" rim ...
check tire rack.com for tire specs
M2B4
Apr 1, 2007 07:49 AM
fafsa
Feb 22, 2005 03:04 AM
drewbie
12
Sep 14, 2004 05:16 AM
slowacura
Nov 13, 2003 08:44 AM
bocian
Oct 1, 2001 02:31 AM
