Can someone give first hand knowledge of the real improvement of the JG 301X cam in the B15B2??
Old Jan 30, 2006 | 12:59 PM
Screaming's Avatar
Default Can someone give first hand knowledge of the real improvement of the JG 301X cam in the D15B2??
Was thinking minime swap but I heard that the MPFI addition and this cam will really livin up the dog D15B2.Any help would be appreciated.Also where can I pick this cam up if indeed it is worth it.Again I'd like someone with first hand experience with this but all opinions are good reading.Thanks Anyone???
Modified by Screaming at 4:42 PM 1/30/2006
Modified by Screaming at 9:24 PM 1/30/2006
Old Jan 30, 2006 | 08:11 PM
Screaming's Avatar
Default Re: Can someone give first hand knowledge of the real improvement of the JG 301X cam in the B15B2??
Come on guy's I only get 5 posts a day and I got alot more questions.I guess a better question would be: Whats the best cam for a D15b2 (I know it's only a D15b2 and I know I should swap it out) but I'm looking for a good cam in the 2,000-6,000 rpm range,something to give it a little more snap down low.Thanks
Modified by Screaming at 9:25 PM 1/30/2006
Old Jan 30, 2006 | 08:50 PM
ED7's Avatar
ED7
The mpfi and another cam will be a big improvement. The crane 251-0012 is a really nice cam. Go to d-series.org for more info.
Old Jan 30, 2006 | 08:59 PM
crxnj's Avatar
That cam is great..Makes power from mid range to +7000rpm,,It's not really a good cam if you want that low end "snap" as you say,unless you advacne the timing a bit and run a 4-2-1 header,,And that cam sounds great at idle,nice and lumpy.
Maybe you should look into a D16a6 cam or even a sohc zc cam..Just by doing the mpfi conversion you're going to notice a gain in performance..
dpine
Jan 23, 2009 03:05 PM
86CRXSi
Jun 14, 2002 11:28 AM
