Convertible top cover (can't get it on...)
Has anybody elese had problems gettig the black cover to snap on when the top is down? I can't get mine on, it just won't quite reach. I went to the Autoshow and was easliy able to get the one there on & off easily. Is there some sort of adjustment I can make or should I just send my new car off to the service dept. at the dealership? Thanks.
I had a lot of issues with my toneau cover at first. It really honest to god wouldn't fit, there simply wasn't anything that I could do to get it to do so.
Just let it sit out, unfolded for a while. preferably in the sun. Let it heat up and stretch out a little bit. It you really want to get it on now, attach one side, and get a hair dryer and heat up the surface of it while stretching it to fit. It just needs to expand a little bit in order to get into the right shape to fit easily and properly.
J
N
J
N
its a pain in the butt to get on. its really tight but im sure there is a reason for it somehow. ask somebody to help if you can. the trick is get one side on and then pull really hard down and to the side.
