B16 OR B18B1 EG HATCH
Old Jan 30, 2006 | 10:51 AM
MxJones92's Avatar
Default B16 OR B18B1 EG HATCH
I am starting with a blank canvas here? I plan on going turbo in the future but never running and crazy lbs? Which one would be better for the price to performance comparison? I am leaning towards an LS because I can go to any local junkyard here in Baltimore and find one but I have never seen a B16 in a yard. I would have to buy one from H motors or somewhere because I wouldnt know where else to find one? But at the same time, VTEC is appealing. What do you all think?
Old Jan 30, 2006 | 10:54 AM
turbotime's Avatar
Default Re: B16 OR B18B1 EG HATCH (MxJones92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MxJones92 &raquo;</TD></TR><TR><TD CLASS="quote">I am starting with a blank canvas here? </TD></TR></TABLE>
haha is that a question? I would go LS and boost it, they are pretty damn cheap. Plus if you decide to get adventurous later down the road you can do the LS/VTEC and then enjoy mad vtak.
LS+Boost is a good cheap plan tho.... compared to b16+boost.
Old Jan 30, 2006 | 11:05 AM
Slow EJ8's Avatar
My $.02.....
-set a HP goal
-then figure out what motor/turbo/etc you will need to accomplish your goals.
Old Jan 30, 2006 | 11:24 AM
mwieczorek43's Avatar
Default Re: B16 OR B18B1 EG HATCH (Slow EJ8)
I'd suggest you get the b16 swap, and put in an LS block.
That way you get the shorter tranny, better flowing head, vtec ecu, and then have the larger displacing block when you change them out.
(I would probably piece them together seperatly so I could pick and choose.. but thats not exactly appropriate for your question)
but that's me..
This is probably the more appropriate answer:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">My $.02.....
-set a HP goal
-then figure out what motor/turbo/etc you will need to accomplish your goals.</TD></TR></TABLE>
Old Jan 30, 2006 | 11:43 AM
.Grimace's Avatar
footwork mastery
Default Re: B16 OR B18B1 EG HATCH (mwieczorek43)
well they all had really good answers so i will try to make mine short but still good. i had a ls swap in my old crx and i wish i had got a b16. if you are boosting it in the future i still would get a b16
Old Jan 30, 2006 | 11:50 AM
jdmpremonition's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest you get the b16 swap, and put in an LS block.
Old Jan 30, 2006 | 02:00 PM
MxJones92's Avatar
Default Re: B16 OR B18B1 EG HATCH (jdmpremonition)
thanks a lot guys all of the info was great does anyone know where to get decent motors cheaper than at hmotors
Old Jan 30, 2006 | 02:09 PM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MxJones92 &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot guys all of the info was great does anyone know where to get decent motors cheaper than at hmotors</TD></TR></TABLE>
If you are looking for a cheep one you might be able to find one in the classifieds section, perhaps even someone local which could save some shipping charges. GL
Old Jan 30, 2006 | 02:13 PM
HATCHingMN's Avatar
both motor are awesome, get the one you find that it's a better deal
Old Jan 30, 2006 | 04:12 PM
MxJones92's Avatar
Default Re: B16 OR B18B1 EG HATCH (HATCHingMN)
On stock internals what psi can each motor hold? Max RPM on each motor (chipped)? What is the max rpm each one can hold or is it all in where power is made?
Old Jan 30, 2006 | 04:26 PM
JdMWoRm2's Avatar
-set a HP goal
Old Jan 30, 2006 | 05:06 PM
vATTACK's Avatar
i would go b18c1...but thats just me...b16a are nice too.
Old Jan 30, 2006 | 05:07 PM
MxJones92's Avatar
Default Re: B16 OR B18B1 EG HATCH (vATTACK)
even though its around 600 dollars difference between the two, when you are working on a tight budget its a lot of money
bbrian
39
Aug 4, 2012 05:48 AM
mikeycivic
Aug 31, 2006 06:05 PM
mikeycivic
Aug 31, 2006 05:29 PM
lacking vtec
Aug 21, 2006 02:46 PM
bagged89hatch
81
Aug 12, 2003 04:09 AM
