need help car Wont start!!!! no fuel getting to fuel rail
Old Jan 30, 2006 | 10:25 AM
civic89si666's Avatar
Default need help car Wont start!!!! no fuel getting to fuel rail
ok so today i got home from skool early because of finals and decided to do some mechanical work on the car....i went outside and took down the gas tank....i took off the two gas lines and one had a ton of gas in it...when i took the rubber hose off it started to spray everywhere.....the other that is on the top directly in the middle of the lid for the fuel pump had some but not a lot....does this mean my some what brand new fuel pump is bad or is it still the relay...when i went to start the car when i frist got it you can hear the relay clicking and somthin in the engine bay clicking but no fuel gettin to the fuel raill....please help me with this i need to know what to buy so i can get this car running ......thanx
Old Jan 30, 2006 | 10:55 AM
civickiller's Avatar
Default Re: need help car Wont start!!!! no fuel getting to fuel rail (civic89si666)
when you turn the key to the on position, do you hear the fuel pump prime?
Old Jan 30, 2006 | 10:59 AM
crxtreme89h's Avatar
Did you let the pressure out first by loosening the screw on top of the fuel filter?
Old Jan 30, 2006 | 11:34 AM
Default Re: need help car Wont start!!!! no fuel getting to fuel rail (crxtreme89h)
the fuel pump doesnt prime at all thats why i thought it was the relay, and i let some of the pressure out but i guess not enough but still i need to find out what the hell is wrong with this car
Old Jan 31, 2006 | 05:22 PM
theres an electrical connector under the rear seats, put a volt meter to it and see if its getting power, if not then its before that, if it does then its after that
blinger
Sep 1, 2007 10:35 PM
EGNA
Jul 12, 2006 03:31 PM
HondaEF
Jul 19, 2004 06:34 AM
hair_rice
Jul 5, 2004 07:37 PM
eg6_lsi
Mar 25, 2004 10:29 PM
