aftermarket intake mani?
i have a 98 itr swap in my gsr. there are two sensors on my wirring harness that are inop right now b/c the itr motor intake mani does not have those two sensor ports that my usdm gsr had. does anyone know if the itr ecu even reads those sensors. my check engine light doesnt come on. also i have the gsr throtle body on my itr b/c the jdm itr motor didnt have the throtle position sensor. is there a good gsr throtle body that has that position sensor that will fit on my itr intake mani.....i have lots of questions...any insight would be aprechiated. thanks
on the GSR intake mani had a Dual secondary butterfly vs with the ITR doesnt have the secondary butterfly for your IAB you should be fine not hooking it up i belive it should be the pink wire and the black yellow wire are the ones your talking about right?
yea those are the wirres, is there a itr throttle body that has the same position sensor that the gsr has....or is there a good gsr throttle body that will work on the itr intake mani?
gsrboost
Jul 9, 2006 08:11 PM
JDM DC2 R
Aug 21, 2002 09:57 AM
